    New 4.0 Xbox 360 Controller problems - with Dreamcast and MAME 2010
    13 Posts 3 Posters 4.6k Views
    • OneSwitchO
      OneSwitch
      I've just upgraded to RetroPie 4.0, and I'm impressed with the N64 improvements. I'm having controller problems though.
      All was working well until the upgrade. Now I have a couple of problems...
      1. My Dreamcast emulator has stopped responding to my custom Xbox 360 joypad configuration. I rewrote it but it's still ignored.
      2. MAME is having problems, especially lr-MAME 2010, lr-MAME 2014 and I think lr-MAME 2003. I'm either getting no response at all from my wired Xbox 360 joypad (linked to a message saying that "...(user space driver) ... not configured". Even though I've set it in RetroArch.
      I'm really stuck. Any help much appreciated. I do have a back-up back to 3.8, but I do like the improvements. If only I can fix the Xbox 360 joypad confusion.
      • herb_fargusH
        herb_fargus administrators @OneSwitch
        @OneSwitch https://github.com/retropie/retropie-setup/wiki/Setting-up-the-XBox360-controller
        • OneSwitchO
          OneSwitch
          Thanks for the reply. I've taken another good look at that chunky page of info but I can't see a solution to my problem there. I tried installing the Xpad driver but it made no difference that I can see.
          My Xbox 360 controller was working pre 4.0 in everything, and now it isn't but only with a narrow range of emulators (lr-mame2010 and KAL-SMU1). My retroarch settings seem correct, and I've rewritten those that I can access for lr-mame2010. I tried rewriting those for KAL-SMU1 that did work perfectly but it makes no difference.
          Any further help would be appreciated.
          • herb_fargusH
            @OneSwitch Did you reconfigure your controller after enabling the xpad driver? (Also did you disable the xboxdrv first)
            • H
              huizingajm @herb_fargus
              @herb_fargus
              Is disabling just going into RetroPie setup and removing the driver or do I need to do something else?
              • herb_fargusH
                herb_fargus administrators @huizingajm
                @huizingajm Yes all you have to do is disable it from the setup script (and then you'll need to reboot)
                • H
                  @herb_fargus
                  You beat me to my edit. Found the Option part of the driver menu and selected Disable. I was having issues with my two controller not working properly. Thanks as always for the quick responses.
                  • OneSwitchO
                    OneSwitch
                    I've enabled the xpad driver (and disabled xboxdrv after, not first - my mistake). I can navigate the RetroPie menus, but I now can't do anything with RetroArch. My keyboard doesn't even work properly now (I guess it was set as a controller).
                    Thanks for quick responses. Hope this can be fixed. Just can't see how to do it now RetroArch GUI isn't accessible.
                    OneSwitchO 1 Reply Last reply Reply Quote 0
                    • OneSwitchO
                      OneSwitch @OneSwitch
                      If it helps, 1.3.6 - No Core is all that appears when I enter the Retro Arch GUI from the RetroPie menu. I have to CTRL+ALT+DELETE to get out of it. Also, the LED ring just constantly flashes now on my controllers, whereas it used to denote player 1 / player 2 Xbox 360 style.
                      • OneSwitchO
                        OneSwitch
                        I managed to get controller access to RetroArch (deleted all the configs), and have set input 1 and 2 to correct settings. Still no access to the Dreamcast, and MAME 2010 seems messed up. If I pull down, I get a weird rapid down effect with the TAB/menu flashing on and off. I can't see anything obviously wrong with the MAME settings. Not sure if things are bugged, or I've done something to trip things up.
                        • OneSwitchO
                          OneSwitch
                          Reverted to old build as things just too unreliable with Xpad driver. Probably something I did, but I can't fathom it.
                          • herb_fargusH
                            @OneSwitch worth trying on a fresh 4.0 just to eliminate any config issues
                            • OneSwitchO
                              OneSwitch
                              Thanks Herb. I think the Dreamcast strangeness was carried over from 3.8 and I only just noticed it later. Seemed to have swapped player 1 to player 2 joypad, but I've fixed that after some head-scratching.
                              Will try 4.0 when I get some spare time. Cheers anyway.
