    RetroPie Setup system possible corrections
    extensionsx68000saturndolphinessystems
    1 Posts 1 Posters 481 Views
    • 2Play2
      2Play
      hello to all & @mitu
      Just wanted to post some more findings
      - PCFX System
      Extension in es_systems are
      <extension>.pce .ccd .cue .iso .chd .PCE .CCD .CUE .ISO .CHD</extension>
      I believe as per RPie Docs should be
      <extension>.img .ccd .cue .iso .chd .IMG .CCD .CUE .ISO .CHD</extension>
      But as per libretro docs to should be:
      <extension>.toc .ccd .cue .chd .TOC .CCD .CUE .CHD</extension>
      Extensions¶
      Content that can be loaded by the Beetle PC-FX core have the following file extensions:
      .cue
      .ccd
      .toc
      .chd
      - DOLPHIN (GC+WII)
      As per libretro docs and since RPie setup has lr-dolphin
      extension should be
      .elf .iso .gcm .dol .tgc .wbfs .ciso .gcz .wad .rvz
      or as per format
      <extension>.elf .iso .gcm .dol .tgc .wbfs .ciso .gcz .wad .rvz .ELF .ISO .GCM .DOL .TGC .WBFS .CISO .GCZ .WAD .RVZ</extension>
      - SEGA SATURN extensions
      As per libretro (lr-yabause, lr-beetle-saturn) I suggest
      <extension>.cue .mds .toc .m3u .zip .ccd .chd .iso .CUE .MDS .TOC .M3U .CCD .ZIP .iso</extension>
      -x68000 extensions
      As per libretro docs I suggest for the core
      <extension>.dim .zip .img .d88 .88d .hdm .dup .2hd .xdf .hdf .cmd .m3u .DIM .ZIP .IMG .D88 .88D .HDM .DUP .2HD .XDF .HDF .CMD .M3U</extension>
      Again just suggestion, findings
      Your friend,
      2Play!
