    Help with pole position 1 and 2 on MAME
    help
    7 Posts 2 Posters 2.1k Views
    • L
      l.chadburn
      Hi guys.
      just need some advice.
      I am trying to play pole position 1 and 2 on MAME.
      I have gone into the menu to set the controls up.
      Three buttons - 1 for accelerate, 1 for brake and 1 for change gear.
      The issue I am having is that when you turn left the car also accelerates and when you turn right the car also brakes.
      Any help is appreciated.
      cheers
      Lee
        Please add some info about your setup, as asked in https://retropie.org.uk/forum/topic/3/read-this-first.
        Which one of the MAME emulators are you using ?
        • L
          l.chadburn @mitu
          @mitu Hi
          I am using MAME-MAME4ALL
          regards
          Lee
            What about the rest of the informations asked ?
            • L
              l.chadburn @mitu
              @mitu sorry
              I'm more into building the cabinets. This is an image I was given by a friend years ago.
              I'll do my best.
              ****3B with Official power supply**
              RetroPie version 4.5.1
              2 player arcade control kit and external speakers**
              Not sure what the rest means to be honest.
              Lee
                I would advise you to start from scratch with the latest RetroPie, we don't know what configurations are in the image your friend has offered you and the version you're using is quite old.
                Instead of mame4all, which is no longer maintained and recommended only for very weak Pi0/1 devices, use fbneo or mame2003-plus for arcade games emulation, they have better integration with the input configuration in RetroPie than mame4all.
                • L
                  l.chadburn @mitu
                  Hi
                  Thank you for your help.
                  I will try and rebuild the image from scratch.
                  Thanks again.
                  Lee
