Videopack problem.
Hello, I am trying to get the videopack emulator working but have not succeeded so far.
I run the latest retropie software, and have installed the odyssee package.
Put the biossen in bios and the games in rom\videopack these are bin format.
When i try to run he game it seems it is loading then after a short while it closes and goes back in the home screen.
I have no clue what is going wrong, any suggestions?
Thanks Jo65 -
@Jo65 please give more details. Filenames of bios / games etc. Setup. See the sticky topic
also support questions go in the support area.
Thank you for the reply
The pie is a version3,
The used software is the latest relaise software,
The not working programs are: al them
The biosses are the ones found on the renee videopack page.The error listed i found : /opt/retropie/suplementary/runcommand.sh: line827: 2281 system fault
@Jo65 said in Videopack problem.:
I need a version number please rather than "latest release" - you can get the version number from the retropie-setup script.
The biosses are the ones found on the renee videopack page.Could be the wrong files - you might want to try some alternative sources. Also see https://github.com/retropie/retropie-setup/wiki/VideoPac-Odyssey-2
I hope this is the one, it scrols fast over the screen. or can i somewhere see it in a help file?
1.4212 -
@Jo65 go into retropie settings. Then go into retropie stup. Then in the top left it displays version. Example 3.8.1 or 4.0 beta 2......
Thanks for the tip, here i see V4.0
Nobody has any idee what could be wrong?
Perhaps somone with the working emulator can tel me where en witch driver they use.
Becouse i have not any idea -
So has been a while. Finaly got it working. Some games are working some not.
Now I just need to figure out how to set the joysticks correctly for the emulator. -
@Jo65 I know this is old but do you remember what it took to get the roms working?
@tu1kfos1 Please open a new topic and add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first. This topic is 2 years old and a lot of things changed in RetroPie since then.
