[SOLVED] No sound in rpix86 through ES
Hi! The title pretty much says it all. I only receive audio in rpix86 when i run the game from the terminal, which is sort of lame. I wonder if the script might negate audio (-a2) when app is launched in ES for some reason. Anyone had this before? If so, how can i resolve this issue? Thanks in advance for your replies!
EDIT:
Alright, i should've done some more digging in the folders before posting.
in ~/.dosbox/emulators.cfg you might wanna add the flag -a0 for HDMI or -a1 for analog audio to work in rpix86.
e.g.: rpix86="/home/pi/RetroPie/roms/pc/+Start\ rpix86.sh %Rom% -a1" -
Audio is set to HDMI out in the launch script - you can change it in
~/RetroPie/roms/pc/+Start rpix86.sh
although note this file will get overwritten on update. -
Saw your edit - You can add it there if that works too (in which case it will actually be sending both parameters but if it takes the last that's fine).
