    Reading roms from both boot sd card and usb flash drive
    dual rom drivesrom help
    3 Posts 2 Posters 240 Views
    • F
      fattiusmaximus
      I am sorry if this has been answered, I did my best to find a answer and couldn't find one. I have a 256gb sd card I boot from that has roms and also a USB flash drive that has roms the issue is that when I boot with the USB drive in it only reads the roms from there and none of the ones on the SD card show up until I reboot and remove the usb drive I couldn't find anything in the documentation nor another forum post about it any help would be appreciated thanks in advance
      Pi Model or other hardware: 4b+
      Power Supply used: (If using a Pi) 5v 3a
      RetroPie Version Used 4.8
      Built From premade image
      USB Devices connected: 2 usb joysticks usb keyboard mouse dongle usb storage device
      Controller used:
      Error messages received: none
      Verbose log (if relevant):
      How to replicate the problem: boot with usb drive containing roms
        How did you set-up the USB drive for ROMs ? If you're using the RetroPie's method of having the ROMs under retropie-mount, then this kind of configuration is not supported - you either use the SD card or the USB drive for ROMs.
        If you wish to have different ROMs folders - some of them on SDcard and some of them on the USB drive - , then you need to devise your own mount strategy and modify the appropriate configuration files with the right commands (i.e. either /etc/fstab or manual mount commands in the autostart.sh file).
        • F
          fattiusmaximus @mitu
          @mitu said in Reading roms from both boot sd card and usb flash drive:
          /etc/fstab
          thank you for your reply ill see if i can figure it out have a blessed evening or whatever it is where you are at!
