    No auto start due to no config found for system fbneo
    autostartfbeneoconfig
    11 Posts 4 Posters 1.3k Views
      sheazer13
      I am trying to launch lr-fbneo with street fighter alpha rom using autostart.sh for a dedicated cabinet.
      It boots and then says no config found for system lr-fbneo
      It launches from the emulation station though.
      Any ideas why this would be happening?
      Pi Model or other hardware: 4b
      Power Supply used: vilros supplied
      RetroPie Version Used 4.8
      Built From: (Pre made SD Image on RetroPie website
      USB Devices connected: Ultimarc APAC
      Controller used: Ultimarc APAC
      Error messages received: no config found for system lr-fbneo
      Emulator: Final Burn Neo
      BuZzB mituM 2 Replies Last reply Reply Quote 0
        BuZz administrators @sheazer13
        @sheazer13 Please provide the details of what you added to autostart.
          mitu Global Moderator @sheazer13
          @sheazer13 said in No auto start due to no config found for system fbneo:
          Most likely your command is incorrect, since there's no lr-fbneo system in RetroPie. FBNeo (the libretro core) is used for a number of systems though, notably arcade, fba, neogeo.
          Post the command that you have added to autostart.sh.
            sheazer13 @mitu
            @mitu I figured out the problem here.
            I needed to put "fba" instead of lr-fbneo
            now im having an issue with the rom
            It loads and plays if I open from emulation station but not from auto start
            S mituM 2 Replies Last reply Reply Quote 0
              sheazer13 @sheazer13
              This post is deleted!
                Maybe it loads with a different emulator from EmulationStation ? But the image is self explanatory - you don't have the correct sfa romset for the FBNeo version.
                  sheazer13 @mitu
                  @mitu from emulation station it's says it is opening lr-fbneo. It says the same thing on auto start but one loads and one doesn't. It even loads the control map that I set in emulation station yet game does not load.
                  Is there multiple versions of fbneo loaded in retropie?
                  mituM RapidEdwin08R 2 Replies Last reply Reply Quote 0
                    No, there's only one.
                    Please provide verbose logs from both runs - see here how to obtain the logs. Post the contents of both logs on pastebin.com and provide the links.
                    • RapidEdwin08R
                      RapidEdwin08 @sheazer13
                      @sheazer13 You can find this info yourself in the runcommand .info after you run it in Emulationstation.
                      Open Emulationstation, run the ROM you want with the Emulator/lr-core you want, Exit, then check the last line of this file:
                      /dev/shm/runcommand.info
                      Here's an example runcommand .info from running 1942 with lr-fbneo:
                      arcade
                      lr-fbneo
                      /home/pi/RetroPie/roms/arcade/1942.zip
                      /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fbneo/fbneo_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/1942.zip"
                      Then just copy/paste that last line into your /opt/retropie/configs/all/autostart sh:
                      emulationstation --no-splash #auto
                      Raspberry Pi B, Pi B+, Pi2 B, Pi3 B, Pi3 B+, Pi Zero W, Pi4 (4GB/8GB), Pi5 (8GB/16GB), Pi Zero 2 W, GPi V1, minisforum GK50 / RetroPie 4.8.x
                        sheazer13 @RapidEdwin08
                        @RapidEdwin08 do I still need to do the original runcommand before the last line to start it?
                        Nothing is happening if I just put the last line
                          @sheazer13 got it to start emulator and game but it is still doing the same things where it says missing rom files.
                          It still loads fine on emulation station though
