    No sound on videos in emulationstation with RPI5 and default cmake settings in retropie-setup
    audio issueraspberry pi 5
    1 Posts 1 Posters 218 Views
    • XenuIsWatchingX
      XenuIsWatching
      I get no sound with the default settings to build the emulationstation-dev from the retropie-setup script. I was able to clone it manually and I was able to deduce what was causing it.
      cmake -DRPI=On -DUSE_GL21=On . is what it builds with by default, and I found that having -DUSE_GL21=On was causing the issue with no sound with the vlc player in emulationstation. Remove this define allowed sound to be played with the video previews.
      /I also followed the readme and build it the way it suggested with cmake -DRPI=On -DUSE_MESA_GLES=On . and then the make and it works good as well
