    need help finding configs directory in retropie
    file directory
    2 Posts 2 Posters 188 Views
      stevejp1978
      i bought an iconic arcade and i got a TOS switchable 4 way to 8 way restrictor... there is an option for running a script in retropie to have it automatically switch to the appropriate mode at game launch.
      the setup instructions tell me to copy all files to /opt/retropie/configs/all but it's not there.
      do I create it?
      don't want to mess it up... and if i don't have to drill out a hole for the manual button that would be a big bonus.
      thanks!
        mitu Global Moderator @stevejp1978
        @stevejp1978 said in need help finding configs directory in retropie:
        If it's not there, then maybe your system doesn't have RetroPie installed. If the system comes preloaded with RetroPie, then you need to ask the vendor for support.
