activer bouton arcade gpio
I noticed a small error (I would even say that it is an incisive detail) but I connected the A player 1 button and it is the B player 1 button which is detected, is this normal or a problem coming from my configuration?
As I explained above, I'm using a TFT screen connected to GPIO in this configuration.
The problem is that the GPIO connections for Player 1's buttons are identical to four GPIO connections on my screen, and for Player 2, there are two GPIO connections identical to those on the screen. (See diagram above.) -
@Jimmy14 said in activer bouton arcade gpio:
This is not specific to your configuration. The assignment could be flipped in the
*.dts
source files (or in RetroArch in upper software layer), but don't go that way (yet) - see my next answer on your next post. -
That is what we will handle now.
Apologies, if I took the long road, but first I wanted to assure that a simple setup with one joystick works.So, as the TFT display uses pins from both joysticks and you can not dual-use a GPIO pin for two devices, I see two options:
One will take a little more space, the other takes less space but needs more fiddling in the*.dts
files.Option 1:
Get two MCP23017 (port expander) on a breakout board, they will use I2C (simple but effective wire protocol) instead of one GPIO port per Button/Direction. Daisy-chain them as I outlined on the Arcade DT project site. The MCP will use the I2C ports of the Raspberry Pi (GPIO2 and GPIO3), which are unused by the TFT. Wire the buttons to the MCP and use the configuration in config.txt instead of thegpio-joystick
entry:# two MCP 23017 connected joysticks, the second with: I2C address 0x21, IRQ on GPIO17 dtoverlay=gpio-mcp-joystick,joy1 dtoverlay=gpio-mcp-joystick,joy2,addr=0x21,gpiopin=17
This should work as GPIO4 and GPIO17 are not used by the TFT display.
If you wire/solder some MCP pin to the "wrong" BTN function you can change the MCP ports to the BTN function in this file. However any changes there need a recompile/re-install and re-boot.
Option 2:
Use one Joystick directly on GPIO and one via an MCP23017. I would go only this path if space is a absolute premium in your Arcade build.It also requires that you only use spare GPIO ports which are neither used by the TFT (thus not GPIO 18,27,10,11,25,8) nor by the MCP23017 (thus not GPIO 2,3,4).
The GPIO ports for Joystick 1 via GPIO should then be entered in
this brcm,pins line, also altered in fragment@3 in the up, down, left, ... sections that each GPIO from fragment@1 (brcm,pins
) is used exactly once.Additionally the Hotkey configuration in fragment@5 and fragment@7 should be adjusted to a spare GPIO (as the currently defined GPIO 2 is needed for I2C and MCP).
Eventually I would remove any even fragment@ (2,4,6,8) entry and anything that relates to joystick2 in
gpio-joystick.dts
(as joystick 2 will be addressed via MCP).That said, I guess using two MCP is the easier option.
Hopefully, my answer is not too confusing. If something is not understood please let me know.
@Lolonois
Since space is a critical factor for my arcade project (transforming a Nintendo NES controller into a portable game console with a small integrated TFT screen), I'd prefer to use the option where I modify the GPIO ports.
I only need to configure player 1; player 2 is useless.
Without wasting your time, you might not have a gpio-joystick.dts file, or at best, a gpio-joystick.dtbo file that matches my configuration. 😅
I'm not sure I'll be able to properly modify and compile the gpio-joystick.dts file to match my configuration. 🤣
Thanks. -
I deleted the .dtbo files that were created during installation in the arcade-dt and overlays folders, then I modified the gpio-joystick.dts file (see below), then I ran the command:
sudo make install
It created a gpio-joystick.dtbo file in the overlays folder, but when I run the command: evtest, I don't get the gpio arcade joystick 1 option to test the buttons.''' /*
- Device Tree Source for GPIO connected arcade controllers.
- Supports up to two controllers with max 13 buttons each.
- Copyright (c) 2024 Gemba @ GitHub
- SPDX-License-Identifier: GPL-2.0-only
#include <dt-bindings/input/linux-event-codes.h>
#include <dt-bindings/gpio/gpio.h>/dts-v1/;
/plugin/;/ {
compatible = "brcm,bcm2835", "brcm,bcm2712", "brcm,bcm2711", "brcm,bcm2710", "brcm,bcm2709", "brcm,bcm2708";fragment@1 { target = <&gpio>; __dormant__ { button_pins1: button_pins1 { /* joy1: up dn le ri st sl tl x y tr a b */ brcm,pins = < 4 17 6 22 19 9 14 15 12 23 24 21>; /* GPIO port numbers */ brcm,function = <0>; /* all input */ brcm,pull = <2>; /* all pull up */ }; }; }; fragment@2 { target-path = "/"; __dormant__ { gpio-joy1 { compatible = "gpio-keys"; label = "GPIO Arcade Joystick 1"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&button_pins1>; /* cf. https://github.com/torvalds/linux/blob/master/include/uapi/linux/input-event-codes.h */ up1: up { linux,code = <BTN_DPAD_UP>; gpios = <&gpio 4 GPIO_ACTIVE_LOW>; label = "BTN_DPAD_UP"; }; down1: down { linux,code = <BTN_DPAD_DOWN>; gpios = <&gpio 17 GPIO_ACTIVE_LOW>; label = "BTN_DPAD_DOWN"; }; left1: left { linux,code = <BTN_DPAD_LEFT>; gpios = <&gpio 6 GPIO_ACTIVE_LOW>; label = "BTN_DPAD_LEFT"; }; right1: right { linux,code = <BTN_DPAD_RIGHT>; gpios = <&gpio 22 GPIO_ACTIVE_LOW>; label = "BTN_DPAD_RIGHT"; }; start1: start { linux,code = <BTN_START>; gpios = <&gpio 19 GPIO_ACTIVE_LOW>; label = "BTN_START"; }; select1: select { linux,code = <BTN_SELECT>; gpios = <&gpio 9 GPIO_ACTIVE_LOW>; label = "BTN_SELECT"; }; tl1: tl { linux,code = <BTN_TL>; gpios = <&gpio 14 GPIO_ACTIVE_LOW>; label = "BTN_TL"; }; x1: x { linux,code = <BTN_X>; /* BTN_NORTH */ gpios = <&gpio 15 GPIO_ACTIVE_LOW>; label = "BTN_X"; }; y1: y { linux,code = <BTN_Y>; /* BTN_WEST */ gpios = <&gpio 12 GPIO_ACTIVE_LOW>; label = "BTN_Y"; }; tr1: tr { linux,code = <BTN_TR>; gpios = <&gpio 23 GPIO_ACTIVE_LOW>; label = "BTN_TR"; }; a1: a { linux,code = <BTN_A>; /* BTN_SOUTH */ gpios = <&gpio 24 GPIO_ACTIVE_LOW>; label = "BTN_A"; }; b1: b { linux,code = <BTN_B>; /* BTN_EAST */ gpios = <&gpio 21 GPIO_ACTIVE_LOW>; label = "BTN_B"; }; }; }; }; fragment@3 { target = <&gpio>; __dormant__ { hotkey_pin1: hotkey_pin1 { brcm,pins = <2>; brcm,function = <0>; brcm,pull = <2>; }; }; }; fragment@4 { target-path = "/"; __dormant__ { gpio-joy1 { compatible = "gpio-keys"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&button_pins1>, <&hotkey_pin1>; hk1: hotkey { linux,code = <BTN_MODE>; gpios = <&gpio 2 GPIO_ACTIVE_LOW>; label = "BTN_MODE"; }; }; }; }; __overrides__ { /* odd fragments for joystick 1 */ joy1 = <0>, "+1+3"; joy1-hotkey = <0>, "+5+7"; /* per dtparam overwriteable */ /* joy1 */ up1 = <&button_pins1>, "brcm,pins:0", <&up1>, "gpios:4"; down1 = <&button_pins1>, "brcm,pins:4", <&down1>, "gpios:4"; left1 = <&button_pins1>, "brcm,pins:8", <&left1>, "gpios:4"; right1 = <&button_pins1>, "brcm,pins:12", <&right1>, "gpios:4"; start1 = <&button_pins1>, "brcm,pins:16", <&start1>, "gpios:4"; select1 = <&button_pins1>, "brcm,pins:20", <&select1>, "gpios:4"; tl1 = <&button_pins1>, "brcm,pins:24", <&tl1>, "gpios:4"; x1 = <&button_pins1>, "brcm,pins:28", <&x1>, "gpios:4"; y1 = <&button_pins1>, "brcm,pins:32", <&y1>, "gpios:4"; tr1 = <&button_pins1>, "brcm,pins:36", <&tr1>, "gpios:4"; a1 = <&button_pins1>, "brcm,pins:40", <&a1>, "gpios:4"; b1 = <&button_pins1>, "brcm,pins:44", <&b1>, "gpios:4"; hk1 = <&hotkey_pin1>, "brcm,pins:0", <&hk1>,"gpios:4"; };
@Jimmy14 pretty close. I was just about to provide you an example
*.dts
but I see you did it already by yourself. Chapeau!For your question:
I assume thefragment@NN
and the numbers in__overrides__
are not aligned in your implementation:These two lines (
joy1
,joy1-hotkey
) below must match thefragment@NN
numbers in the*.dts
:Currently you have:
But it should read as:
__overrides__ { joy1 = <0>, "+1+2"; /* fragment@1 and fragment@2 */ joy1-hotkey = <0>, "+3+4"; /* fragment@3 and fragment@4 */
Which means for the device tree parser: If in
config.txt
thejoy1
is set then do load fragments one and two, and ifjoy1-hotkey
is set inconfig.txt
do load fragment three and four, which should be defined already in the dts file.If they can't be found they are silently not loaded, unless you have set
dtdebug=1
in yourconfig.txt
and examine the log withsudo vclog -m
after reboot.Hope this helps.
