    EmulationStation Issue running roms
    emuationstation
    2 Posts 2 Posters 211 Views
      cantercrow
      Hi,
      I am just setting up and I can't run N64 roms, the command works from the ccomand line in Windows but EmulationStation log has the error below.
      lvl2: Attempting to launch game...
      lvl2: E:\Emulation\Nintendo64\Emulator\Project64 3.0\Project64.exe "E:\Emulation\Nintendo64\Roms\DisneysTarzan.7z"
      lvl1: ...launch terminated with nonzero exit code 1!
        Which EmulationStation version are you using ? Perhaps you need to quote the path to the emulator, since it has spaces in it, or try to rename the "Project64 3.0" folder to not have spaces in it. How is the es_systems.cfg file set-up for the N64 system ?
