    Is Retropie right for me? Are there alternatives?
    retropie
    27 Posts 3 Posters 9.5k Views
    • U
      ubernub @BuZz
      @BuZz http://pastebin.com/jP5jqWSp
        BuZz administrators
        for some reason usbmount doesn't like it - did it mount ok manually ?
        what is the output of sudo parted /dev/sda print ?
        • U
          ubernub @BuZz
          @BuZz
          pi@retropie:~ $ sudo mount /dev/sda1 /mnt
          mount: unknown filesystem type 'exfat'
          pi@retropie:~ $ sudo parted /dev/sda print
          Model: Samsung Portable SSD T1 (scsi)
          Disk /dev/sda: 500GB
          Sector size (logical/physical): 512B/512B
          Partition Table: msdos
          Disk Flags:
          Number Start End Size Type File system Flags
          1 32.8kB 500GB 500GB primary boot
            BuZz administrators
            It is not NTFS. It is exfat formatted
            try this
            sudo apt-get install exfat-fuse exfat-utils
            and try the mount commands again.
            or use FAT32/NTFS
            • U
              ubernub @BuZz
              @BuZz That worked! I can mount it now, but how do I get it to see the roms on it?
                BuZz administrators
                Did you read this https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
                • U
                  ubernub @BuZz
                  @BuZz Thank you! That fixed the rest of it. I had to change the filesystem to exfat-fuse instead of vfat but otherwise it worked perfectly. :)
