    Installed Waveshare 5" HDMI LCD, No sound output 3.5mm jack [SOLVED]
    10 Posts 2 Posters 4.9k Views
    • TwoGuidosGamingT
      TwoGuidosGaming
      Hi, how can I get the sound output via 3.5mm jack? Im using the waveshare 5" LCD with HDMI connector? I tried to update the audio settings in Retropie to use 3.5mm. But wont let me change it to that option.
      • senkunS
        senkun
        sudo nano /boot/config.txt
        add hdmi_drive=2 to the end
        See if that works. if not, try this and see sudo amixer cset numid=3 1
        Could you pm me where you got it from? Looking to buy one of those as well, that was way fast shipping, weren't you having trouble with a kedei screen just a few days ago?
        TwoGuidosGamingT 2 Replies Last reply Reply Quote 0
        • TwoGuidosGamingT
          TwoGuidosGaming
          Thanks for your reply, seems it didnt work. And yes my volume is turned up in retropie. I keep getting some error when trying to force audio via 3.5mm in raspi-config
          • TwoGuidosGamingT
            TwoGuidosGaming
            got it working, it seems i have to go to terminal and have to load the driver.
            sudo modprobe snd-bcm2835
            but i have to do it everytime i reboot
            any way to make the automatically load?
            • senkunS
              senkun
              is this a clean install of retropie 3.7?
              check your /boot/config.txt and see if you have this enabled in there;
              dtparam=audio=on
              TwoGuidosGamingT 1 Reply Last reply Reply Quote 0
              • TwoGuidosGamingT
                TwoGuidosGaming @senkun
                @senkun thank you that worked, I dont know why, itried that before and it didnt work :)
                • TwoGuidosGamingT
                  @senkun Yes I have a kedei screen 3.5", but wanted something for retropie as I could not get the 3.5" to work. Yes. very fast shipping... this person shipped it in 1 day. got it for $20 w/free shipping. Even came with some kind of 3d printed enclosure, that the lcd and pi fit into which was not in the item description on ebay.
                  • TwoGuidosGamingT
                    @senkun Cant figure how to PM someone , but i got it on ebay from an individual, not a normal seller. Id say I got lucky with one. The description said "5" for Raspberry Pi HDMI LCD 800x480 Pixel XPT2046 Touch Controller
                    I know nothing about these so please look at photos - this has not been tested and as is"
                    • senkunS
                      senkun
                      @TwoGuidosGaming $20? For the 5" HDMI screen? That's a great deal! And with some enclosure too? One of these?
                      Yeah I thought we had pm, I just checked but can't find any way. I thought nodebb had pm somehow.
                      • TwoGuidosGamingT
                        TwoGuidosGaming
                        this is what i got
                        http://www.banggood.com/5-Inch-HDMI-TFT-LCD-Touch-Screen-For-Raspberry-PI-With-Case-p-977666.html
                        but like i said, it was sold from an individual who had no idea about it, they didnt even know it had a screen on the other side, they thought it was just a piece of electronics, lol.
