    Custom Aspect Ratio in Final Burn Alpha.
    fba-nextretropieruncommand
    2 Posts 1 Posters 1.4k Views
      silentq
      I have noticed a couple of games in FBA seems to have a custom aspect ratio. While I can change this in RGUI, specifically in Street Fighter III: 3rd Strike I notice its set to a 16:9 aspect ratio which doesn't fit the game at all since its a 4:3 game. What my question really comes down to how can I change this permanently for this game only. The runcommand seems to only affect the resolution and not the aspect ratio. Is it possible to change aspect ratio exclusively and permanently to one game? Or is this something that would need to be changed in a setting elsewhere?
        silentq
        So an update here after some playing around I am noticing that the runcommand is not saving the any video resolutions I change. I thought it was only changing resolution thus the aspect ratio wasn't changing but apparently it should also be changing aspect ration since its in the options. When I press select on my DS3 to change an option it doesn't see to show the option change in the parenthesis. So I think this is actually a runcommand issue?
