    [IDEA] Use RetroArch's built-in per-ROM config functionality, rather than runcommand and -appendconfig
    runcommandconfigcfgretroarchidea
    11 Posts 6 Posters 6.1k Views
      dankcushions Global Moderator
      i've been experimenting with retroarch's built-in per-ROM override ability (eg https://retropie.org.uk/forum/topic/4046/crt-pi-shader-users-automatic-usage-of-crt-pi-vertical-in-vertical-games-in-lr-mame2003). it's quite nice in that it lets you go into the RGUI menu, make option changes, and then select 'Save Game Overrides', and it will generate a gamename.cfg file in a subdirectory (named after the core) of your config directory, which will be loaded every time you launch that game.
      i thought maybe we could utilise this in retropie, rather than the current per-rom cfg method which can be complex - https://github.com/retropie/retropie-setup/wiki/retroarch-configuration#hardcoded-configurations & https://github.com/retropie/retropie-setup/wiki/runcommand (option 9)
      i'm happy doing the code changes, but wanted to get some feedback before starting :) here's the pros/cons i can think of:
      PROS:
      • allows users to adjust configs via the retroarch RGUI, rather than manually create them via runcommand text edit.
      • reduces scope/complexity of runcommand and leaves (this) retroarch stuff to retroarch
      • uses the supported RA method for this
      • if you have 'save config on exit' turned on, your overrides will not migrate into your main .cfg
      • alerts the user that an override has been loaded (current method is silent)
      CONS:
      • would make users' old per-rom .cfgs redundant (could keep old retrieval code in runcommand?)
      • the old method essentially works fine :)
      i haven't tried this with per-core configs, although RA also supports those overrides in the same way. this part would need thorough testing, though, as it's such a crucial part of retropie. save that for another day :)
        meleu @dankcushions
        @dankcushions
        This pro is enough to go ahead!! :D
        • Z
          Zigurana
          I agree that editing the settings from within the RetroArch interface makes a bit more sense, UI-wise.
          Questions :
          • where does RA store those per-game settings?
          • can we access these from anywhere else, for instance from the command line or via SCP?
          • can we provide a conversion from the current per-game cfgs to the other?
          dankcushionsD 1 Reply Last reply Reply Quote 1
            dankcushions Global Moderator @Zigurana
            @Zigurana said in [IDEA] Use RetroArch's built-in per-ROM config functionality, rather than runcommand and -appendconfig:
            Questions :
            "it will generate a gamename.cfg file in a subdirectory (named after the core) of your config directory"
            eg /opt/retropie/configs/mame-libretro/MAME 2003/pacman.cfg
            they're just text files so sure :)
            sure - just moving and renaming would do it, which you could do via linux commands.
            Z 1 Reply Last reply Reply Quote 1
            • Z
              Zigurana @dankcushions
              @dankcushions well then, there is not much of a difference is there?
              We can write a conversion script to move any existing cfg from the rom folder to the new /opt/... location, so ppl will not have start from scratch if they have shaders/overlays installed.
              There's probably a couple of Retropie specifics that need to be updated, but some of the @administrators will be able to comment on that.
              What about the use case of someone wanting to switch from one libretto-core to another? He/she will start with a blank config in that case, right?
              Now I think about it, that's probably a good thing, as a different core will also need different configurations.
              I say, its a minor change, with minor impact, and brings some improvements towards the hassle of setting up a game. Good plan!
                BuZz administrators
                Thanks - looks good.
                There is another thing to consider with the current method. I have my roms on a network mount, and so any rom overrides affect all systems that use it. With the new method, that would be lost but I don't see why we can't allow for both.
                I will look into it. I would prefer to do the code though (Although not much will be needed I think - mostly just switching it on). I will want to do some testing to make sure it all works etc.
                • GreenHawk84G
                  GreenHawk84
                  I would also enjoy per-rom overlays savable in RetroArch GUI. But maybe that already exists and I can't figure it out. I don't want to do anything complicated. Just let me select an overlay per rom in the GUI. No command line stuff and no .cfg editing.
                    dankcushions Global Moderator @GreenHawk84
                    @GreenHawk84 said in [IDEA] Use RetroArch's built-in per-ROM config functionality, rather than runcommand and -appendconfig:
                    it exists and i describe how in my first post :) if you can't find the option it might only be in later versions of retroarch. i'm not sure how long it's been there.
                    FloobF 1 Reply Last reply Reply Quote 0
                    • GreenHawk84G
                      GreenHawk84
                      @dankcushions , whatever you can do you simplify Retropie, is great news to me.
                      • FloobF
                        Floob @dankcushions
                        @dankcushions I think the stock RetroArch in RetroPie 4.02 is from July, whereas this change was about 26 Aug.
                        https://github.com/libretro/RetroArch/pull/3429
                        I'll update mine and try it out, although I guess until its within the RetroPie image download most users probably wont come across it as I doubt they would update RetroArch.
                          BuZz administrators @Floob
                          @Floob yeah - it was after the 1.3.6 release - when the next retroarch release is out I will do some testing etc. (well may test before, but it won't be enabled in retropie until after the point release).
