    Second controller work with snes and megadrive, not with fba, neogeo or master system
    input
    5 Posts 2 Posters 1.6k Views
      jijiz
      Hi,
      I'm looking for some days how to make work second controller on master system, fba and neogeo. Second controller is working on megadrive and snes emulator.
      I tried to do solve this issue with :
      -retropie-joystick-selection script,
      -edit joystick-selection.cfg http://pastebin.com/SjXfAURx and retroarch.conf of neogeo directory : http://pastebin.com/NUHHD9J7,
      -tried to uncomment input_player1_joypad_index = "1", input_player2_joypad_index = "0", input_player3_joypad_index = "2" of retroarch.cfg from "all" directory : http://pastebin.com/e7DjTene.
      -I also tried to compare snes and neogeo directory.
      No effect, I can't insert coin or start second player in neogeo game.
      Do you have an idea ?
      Thanks you for your help et sorry for my poor english.
        jijiz
        found solution :
        http://www.gamoover.net/Forums/index.php?topic=31942.0
        Master system configuration : launch game, hit F1, configure input.
        But still have message "controller XX not configured" when launching master system, so I can play with 2 player but cannot exit game.
          meleu @jijiz
          I noticed that the #include directive (last line) of your neogeo/retroarch.cfg is wrong. The # symbol is necessary. This way:
          If this doesn't solve your problem, I would like to see your working configs (eg: megadrive/retroarch.cfg).
            meleu @jijiz
            I think it's happening due to the same reason I mentioned in my previous post: the lack of the # character in the #include directive on mastersystem/retroarch.cfg.
            Did you delete this char?
              jijiz
              Indeed it was the problem, I restored the original file with # char. That's ok, everything is working. Thanks for your help
