    Daphne MACH3 no sound :(
    daphne
    7 Posts 4 Posters 2.2k Views
    • N
      Nicodemus
      Pi Model: 3
      RetroPie Version Used: 4.01
      USB Devices connected: PS4 controller and Keyboard
      Controller used: PS4 wired
      Mach3 runs but with poping sounds and VERY quick garbaled speech? I parsed the files in retropie and checked all the setting but it just dosent want to emulate sound correctly. Anyone else had this problem or know of a solution?
        proaudiosoft
        Have you even bothered to view the compatibility list on it? Theres your answer
        https://docs.google.com/spreadsheets/d/1Hy2VpPXgs4a9imeu0_w3SpehKEkhUNOLzD1jhcgwS3o/edit#gid=0
        • N
          Nicodemus
          Thanks! I didn't even think of looking there (Face Palm)
            proaudiosoft
            0_1475928360109_search.jpg Its all good lol
            • N
              Nicodemus
              How do I mark this as solved?
                mediamogul Global Moderator @Nicodemus
                @Nicodemus
                Under your first post, there are a row of buttons. I believe it's under the button marked 'Topic Tools'.
                  BuZz administrators
                  You can also set a specific post as the answer too. - by clicking the 3 dots icon on a post (I have done this for this thread)
