PSX ROMs sound issue
Hi chaps,
I've downloaded a few PSX game roms (BIN file) I've added the correct Cue file and they work perfectly, apart from the music, which comes through sounding like static from a radio, although the SFX are fine, What am I missing?
Yes, same case here! Raspberry Pi 3 and latest Retropie release 4.1. Using default lr-pcsx-rearmed emulator. Sound/music jitters. Maybe that has to do with the audio driver? Alsa is enabled by default. But I think there are other two audio drivers that can be enabled for this emulator. Maybe there is the key.
Having same issues with games that have multiple tracks. Audio files having the issue end with .ape format.
I have tried to turn them into .wav files. Doesn't make a difference.Have anyone solved this problem ?
