    Problem with PS3 controller via Bluetooth in UAE4ARM
    uae4allps3 bluetoothremapping
    3 Posts 3 Posters 1.6k Views
      pacific23
      Hi!
      I'm using PS3 controller with a Bluetooth connexion and I have a problem in UAE4arm : The fire button is mapped onto the Select button.
      How can I change this. Can I make a custom Retroarch.cfg ? I think this doesn't work because UAE4ARM is not Retroarch compliant.
      Thanks and best regards
      Yoann
        edmaul69 @pacific23
        @pacific23 the problem with a lot of computer emulators use button 0 as the "a"/ "1" button. Button 0 on your controller is assigned to the select button. If the emulator does not have its own controller config there isnt much you can do. I do not use that emulator so i couldnt tell you if it has one or not.
          the19thbear
          Any news on this? Same problem here. Any other controller that is working better?
          Pi Model: 3 b+
          RetroPie Version Used: 4.1
          Built From: premade retropie image
          USB Devices connected: USB hdd
          Controller used: 2x ps3
