    PS3 (Shenzhen Senze) controller
    ps3 controllerps3 bluetoothps3 problemsps3 clonessz-902b
    31 Posts 2 Posters 9.8k Views
      BuZz administrators
      please can you reboot and ssh in and post the output of
      /etc/init.d/sixad status
      please use a code block to format - http://commonmark.org/help/ (three backticks above and below)
        BuZz administrators
        also please remove / reboot / re-install it again , then reboot and run the above command.
          Paholainen @BuZz
          @BuZz just saw your post. Will do it tomorrow morning.
            Paholainen
            Before re-install
             sixad.service - LSB: Start sixad
               Loaded: loaded (/etc/init.d/sixad)
               Active: active (running) since Wed 2016-10-19 20:17:03 UTC; 11h ago
              Process: 403 ExecStart=/etc/init.d/sixad start (code=exited, status=0/SUCCESS)
               CGroup: /system.slice/sixad.service
                       ├─ 442 sudo /usr/bin/sixad --start
                       ├─ 496 /bin/bash /usr/bin/sixad --start
                       ├─ 684 /usr/sbin/sixad-bin 0 0 0
                       └─3839 sleep 5
              Paholainen
              After remove/reboot/installing (did not try to pair)
                 Active: active (running) since Thu 2016-10-20 07:30:26 UTC; 1min 34s ago
                Process: 1830 ExecStart=/etc/init.d/sixad start (code=exited, status=0/SUCCESS)
                         ├─1837 /bin/bash /usr/bin/sixad --start
                         ├─1885 /usr/sbin/sixad-bin 0 0 0
                         └─2173 sleep 5
                Paholainen
                Tried to pair, no luck
                  BuZz administrators @Paholainen
                  @Paholainen It's running correctly, so not sure why the official ps3 controller won't pair. Mine pairs fine. I just connect USB, disconnect and press button. I'm out of ideas, sorry.
                    Paholainen @BuZz
                    @BuZz I even tried 3 different cables and on two separate Raspberries. When I plug it in nothing happens with the lights on the controller. I´ll just have to use my 2,4ghz dongle gamepad instead
                      BuZz administrators
                      the controller doesn't even work when connected via usb ? That's the main problem then as that's the point where the controller is "told" to connect to the raspberry pi bluetooth when disconnected. It should work out of the box over usb.
                      In case something is wrong with your install, you should download a fresh images, then update it before doing anything else via retropie-setup, then try. If you get the same problem, I suspect it's a hardware issue or something with your controller that makes it incompatible.
                      P 2 Replies Last reply Reply Quote 0
                        Paholainen @BuZz
                        @BuZz Downloaded fresh image, and did the steps. still same issue. Strange that none of the two ps3 controllers worked via cable or BT, on two different Raspberries. The controllers are confirmed working on a PS3
                          Paholainen @BuZz
                          @BuZz Thanks for trying to get it fixed.
