    HOWTO: Pro Pinball: Timeshock! in Dosbox on Rpi3
    pro pinballdosboxrpi3timeshock
    88 Posts 17 Posters 35.4k Views
    • BobHarrisB
      BobHarris
      I'm having a rather odd issue with this game.
      During the time travel the light sequence is off completely. The lights are first supposed to go up and then downwards. In my game they're all over the place.
      I patched it to version 1.07.
      Does anybody know why this is happening?
      (P.S. The music sounds bad, but that is just my crappy camera.)
      UPDATE: never mind; it was a graphics setting in the Timeshock menu (details were set at 'low' , which has an effect on the light show).
      Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
        darky2003
        any youtube vid for this :s ?
        BobHarrisB 1 Reply Last reply Reply Quote 0
        • BobHarrisB
          BobHarris @darky2003
          @darky2003 No it's quite a niche subject matter. If you really want to get this going you'll have to read through this topic..all the info you need is in here.
          • BobHarrisB
            BobHarris @mi7chy
            @mi7chy You are right! This solves the issue with the GOG Timeshock edition.
            Now if we could only get rid of the choppy ball movement..it doesn't seem to be a performance issue as lowering graphics/audio settings does not improve the ball movement.
            • quicksilverQ
              quicksilver @BobHarris
              @bobharris have you tried increasing the emulated CPU speed using cntrl+f12?
              • BobHarrisB
                BobHarris @quicksilver
                @quicksilver Thanks for the suggestion..I tried it, but it had no effect.
                  edmaul69 @BobHarris
                  @bobharris check your dosbox-SVN.conf and set these settings
                  language=
                  machine=svga_s3
                  captures=capture
                  vmemsize=8
                  memsize=63
                  and
                  core=dynamic
                  cputype=pentium_slow
                  cycles=max 105%
                  cycleup=10
                  cycledown=20
                  the vmemsize or memsize, one of them actually needs to be added as it isnt in it originally. for cycles max or 100% for whatever reason only runs it at 95%.
                    edmaul69 @BobHarris
                    This post is deleted!
                    • BobHarrisB
                      BobHarris @edmaul69
                      @edmaul69 I made the changes and tested them on both the GOG version as well as the version I created from the original cd. It did not improve ball movement. (version 1.00 or patched to 1.07 did not make a difference either.) Hitting Ctrl F11 did make the ball skip around a lot more, but hitting ctrl F12 could only make it as good as I've seen it before.
                      Are you positive ball movement in your game is completely smooth? I mean it's quite playable, but I do notice the ball skipping very small distances, most noticably when the ball doesn't have a lot of speed. But I'm sure the skipping is small enough that it would be hard to capture with my camera.
                      This topic also describes the difference in ball movement between the DOS version and the Windows 1.20 version:
                      https://www.gog.com/forum/pro_pinball_series/windows_version_of_timeshock
                      I have the Timeshock 1.20 kickstarter edition (I was a backer for the Ultra version) for Windows on my laptop and there is zero jerky ball movement. (Actually I just checked and I don't see anything about '1.20', the kickstarter windows version shows '1.08')
                      But I just like playing the game on my hdtv so much more.
                      If you have completely smooth movement then I'd really like to compare settings:
                      https://ufile.io/qvu32 (my dosbox-SVN.conf file) I don't know if mem_size=63 was a typo or not, I also tried 64, but did not make a difference.
                      I have not overclocked my Pi 3. I don't think it would make a difference. Otherwise I think lowering the resolution should have improved ball movement and 4 balls at the same time should have worsened it, but no such things happened.
                      In game settings:
                      Table view: widest
                      Graphics:
                      Screen flipping: Enabled
                      Resolution: 1024x768
                      Colours: 256+
                      Detail: Custom ( -> Half speed, medium, maximum, minimum, disabled, 100%)
                      Dot matrix: Intelligent transparent
                      Nudge scrolling: Two way
                      Audio:
                      Mode: Stereo
                      Quality: Medium
                      Music restart: Quick
                        edmaul69 @BobHarris
                        @bobharris vmemsize=63 was not a mistake. take it off of 64. there is an issue with going above 63. i am using a 1.00 version from the web. here are my dosbox config files and a video starting with the settings im using:
                        https://drive.google.com/open?id=1wJIpN9JoaMUvLEmaWZp4aBLPdXbvA5su
                        • BobHarrisB
                          BobHarris
                          I copied your config file to my Pi, but I don't see an improvement.
                          I added a video of me playing, but I can't really see the judder in the YT video..you either have to see it yourself on the tv, or directly record video from the tv. Both things are impossible, so I will just settle with a bit of judder. I guess Cunning developments patched it out of the Windows version, but kept it in the Dos version.
                            edmaul69 @BobHarris
                            @bobharris and as for pro pinball the web i couldnt get the version i had to work because it couldnt detect the “cd being in the drive” the exodos version worked though.
                            • BobHarrisB
                              BobHarris @edmaul69
                              @edmaul69 I never really got into the other 3 tables. To me Timeshock got everything perfect..the complexity, the layout, the music, the voice and I especially like all the ways you can prevend losing the ball (the 'lucky' slot on the left, magnosave on the right, ballsaver, pin in the middle, nudging).
                                A Former User
                                Hi,
                                i installed Timeshock! as you're Manual.
                                I don't understand how to create the startup script.
                                Im connected via ssh from my mac with Terminal, then i copy
                                /opt/retropie/emulators/dosbox/bin/dosbox
                                -c "@mount c $HOME/RetroPie/roms/pc/pptime"
                                -c "@imgmount d $HOME/RetroPie/roms/pc/pptime/pptime.cue -t iso"
                                -c "@c:"
                                -c "@pinball"
                                to the Terminal . After hit Enter the following Message comes:
                                Exit to error: Can't init SDL Unable to open a console terminal
                                This can't be correct. Can you help me how i can create the Startup File?
                                Thank you very much!!!
                                  edmaul69 @A Former User
                                  @Andreash Do it this way and save yourself the trouble. You may need to edit the +dosbox.sh file for this to work if it isnt setup to run .conf files. Also make sure your files are named and in the correct locations as listed in info below. You need to create a file called Timeshock!.conf in /home/pi/Retropie/roms/pc/ in that file add info below and save. Reboot emulationstation.
                                  [autoexec]
                                  mount c /home/pi/RetroPie/roms/pc/pptime
                                  imgmount d /home/pi/RetroPie/roms/pc/pptime/pptime.cue -t iso
                                  c:
                                  pinball
                                  • quicksilverQ
                                    quicksilver
                                    I know this topic is a few months old, but was curious if anyone has tried running the CD version via windows 3.1 in dosbox and if that might take care of the ball judder?
                                    • BobHarrisB
                                      @quicksilver I don't think so, but I'd love to see someone try.
                                      I've played a lot of Timeshock on my Pi now and have gotten used to the small amount of judder, it doesn't bother me anymore really.
                                      • quicksilverQ
                                        @bobharris I will try it out and see what happens. I just got win 3.1 setup through dosbox on my pi and have CD games working well. I just need to find the CD version of this game and I'll try it and report back.
                                        BobHarrisB 1 Reply Last reply Reply Quote 1
                                        • BobHarrisB
                                          @quicksilver You should be able to find it somewhere. If you live in the Netherlands I could send you my disc (dont need it anymore)..otherwise postage would be expensive.
                                          • quicksilverQ
                                            @bobharris im sure I can locate a copy. I'm in the US so you probably wouldn't want to send me yours. Thanks for the offer though!
