    HOWTO: Pro Pinball: Timeshock! in Dosbox on Rpi3
    pro pinballdosboxrpi3timeshock
    88 Posts 17 Posters 35.4k Views
    • BobHarrisB
      BobHarris @quicksilver
      @quicksilver I just looked it up and it's not too expensive, so let me know if you can't find it.
      Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
      • quicksilverQ
        quicksilver @BobHarris
        @bobharris I was able to locate a bin/cue image of the game. It doesn't look like the install through windows 3.1 is any different than straight through dos. Some games have a different install process through windows and use higher quality audio/video etc. Timeshock it seems to be the same. The slight jitter with the ball is still present unfortunately.
        BobHarrisB 1 Reply Last reply Reply Quote 0
        • BobHarrisB
          @quicksilver
          https://www.gog.com/forum/pro_pinball_series/windows_version_of_timeshock
          Here they are talking about how a certain windows patch removes the jitter. But I've only read about patch 1.20b, I've never seen it.
          • quicksilverQ
            @bobharris I found a source for the patch, I will try it out and see what happens. Though it looks like it might be a patch for Windows XP?
            Edit: I tested the patch and it appears to not work at all through windows3.1
            • BobHarrisB
              @quicksilver Ah too bad. Well at least we know a bit more now. What helped for me was setting the tv brightness a bit lower. It made the judder a lot less noticable.
                rsn8887
                I found the fix for sfx in an earlier post: soundaster irq has to be set to 5 not 7
                  edmaul69 @rsn8887
                  @rsn8887 did you try this out? On the pi soundblaster uses irq 7. You would have to change it to irq=5 in the dosbox-SVN.conf to use irq 5 and i dont see that doing anything different.
                    m99999
                    ... are there any remaining problems? on my raspberry 3b+ it is running perfect with all sounds ... but i have to do a lot of changes to make it work ...
