    Kodi - audio and subtitles stream language unknown
    kodiaudiostreamraspberry pi 3
    11 Posts 3 Posters 4.6k Views
      MadHorse
      Hi all,
      I have installed kodi so i can launch it from Emulation Station Menu.
      It is working very well, but i have a little problem.
      When i play an MKV file, Kodi correctly recognize both audio and subtitle stream language name (for example English - AC3 5.1) but when i play a BluRay ISO or a BluRay Folder, the video is played correctly, i can select all the audio and subtitles stream but the language name is not displayed, i see a list of audio stream named Unknown - DTS 5.1 Unknown - AC3 5.1 etc.
      Before i've used OpenElec or OSMC and both was able to display stream language, but i don't know how to do it.
      Someone can help me ?
      Pi Model: Raspberry Pi3
      RetroPie Version Used: 4.0.2 (After the update 4.0.5)
      USB Devices connected: Wireless Keyboard, USB Pen Drive or Hard Drive
      Thank you in advance.
      RascasR 1 Reply Last reply Reply Quote 1
      • RascasR
        Rascas @MadHorse
        @MadHorse That depends on the metadata information of the file, not Kodi. I don't think there is options for that. Mostly likely that in OpenELEC and OSMC you used a bluray with that info and a bluray without that in RetroPie.
          MadHorse @Rascas
          @Rascas
          thank you for your answer.
          I thought the same thing at first, when the language and subtitles shows as unknown i installed OpenELEC 6.0.3 and tried the same blu ray folder movie.
          On OpenELEC the language are displayed correctly, so the metadata is not the problem.
            backstander
            @MadHorse
            I have an idea of what it might be...
            In OpenELEC, go into the Add-on section in Kodi and look to see which Add-ons are installed. I wonder if there's an extra Add-on that does this. If so then install that same Add-on in Kodi on RetroPie.
              MadHorse @backstander
              @backstander
              Thank you for your help.
              I thought that one too and it doesen't seems to be an addon that get the audio and subtitles stream language, but i have to admit i didn't compare deeply the addons installed on both.
              I will take another look.
              • RascasR
                Rascas
                Please post your Kodi log, to something like pastebin, after playing something with that behaviour. It would help if could also upload a sample of the bluray to somewhere and leave the link here for people to test it.
                  MadHorse
                  Hi all,
                  sorry for my late answer.
                  @backstander i've checked and it doesen't seems to be any relevant differences between the addons installed on OpenELEC and those on RetroPie.
                  @Rascas [Link removed] you can find a kodi.log after i played a Blu Ray ISO with the problem.
                  Anyway, i decided to create a dual boot SD with LibreELEC + RetroPie to bypass the problem and have the best of both world.
                  I would like to thank you all for you answers and help, i really appreciated.
                  Thank you.
                  • RascasR
                    Rascas
                    Hmmm... the log should be with debug enabled, there isn't enough information in that log about the problem:
                    http://kodi.wiki/view/Log_file/Easy
                    The only thing I can think off than can cause this, is the libbluray version.
                      MadHorse
                      @Rascas
                      sorry, HERE you can find the debug log while i'm playing a bluray folder.
                      Thank you
                      RascasR 1 Reply Last reply Reply Quote 0
                      • RascasR
                        Rascas @MadHorse
                        @MadHorse Thanks, it is indeed because of libbluray more specifically BD-J support. I will compile also libbluray for the next Kodi version.
                        M 1 Reply Last reply Reply Quote 2
                          MadHorse @Rascas
                          @Rascas
                          thanks to you.
