    Pi in a Gameboy Advance Build - WIP
    gameboy advancegbabuildhandheldproject
    240 Posts 18 Posters 192.6k Views
      Some repeated scoring with an xacto knife along the seam of the plastic got me inside, and this is a very dense device.
      The headphone and microphone jacks are surface mount, which I stink at removing, and the usb plug is surface mount with through hole supports. I mangled the HDMI port and Micro USB on the Pi 3 when I removed those, but on this thing, I can't do that. Not to mention that this is very small, and I'm sure it will load up with heat quickly. I'm not going to attempt to remove anything tonight as it's getting late and I don't want to mess it up. If anyone has any tips for desoldering that USB port, or for removing the headphone and mic jack without heat soaking the whole board and messing something up, please chime in.
      I made sure to test the board with the shell off before trying to remove things, and a few rounds of Zed Blade for this week's MAME ROW had me confident that it's working as it should.
      mooseprM 1 Reply Last reply Reply Quote 0
      • mooseprM
        moosepr @obsidianspider
        @obsidianspider yeah those headphone Jack's look a bit tricky. Can you even fit a soldering iron between them?
        I would be tempted to get the cutting disk on the dremmel and slice the Jack's down the middle. That should let you then unsolder the outer pins, then remove the plastic, then the inner pins maybe?
        want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
          obsidianspider @moosepr
          @moosepr said in Pi in a Gameboy Advance Build - WIP:
          Maybe, but not easily, and I'd end up melting plastic all over the tip.
          That sounds like a good strategy since I'm not trying to preserve the jacks. I think the plan will be to try removing the mic jack since I don't intend to ever use that functionality, so if I mess it up it's acceptable. Then I'll plug it into the Pi to test. Then I'll remove the headphone jack, and plug it into the Pi and make sure that it is detected. After that I'll try attaching leads to the headphone jack and connect it up to one of the new headphone plugs I got from China (maybe it's good they came as a 10-pack) and test again. Then if that's working I'll go after the USB plug, and test again.
            I made some good progress tonight. @moosepr 's suggestion about using a dremel on things before trying to desolder them worked well. Just for a sense of scale, that sound card PCB is about 2cm square.
            I managed to connect up the volume wheel and Adafruit amp, and everything works.
            For anyone who is also going to try to figure this out with their own build, running speaker-test -c2 at the terminal will cycle white noise back and forth between left and right so you can make sure you have the proper channels identified.
            When I plug in the headphones, the sound to the speaker shuts off, so that's good, but I am noticing some electrical noise coming from the speaker that is tied to activity on the Pi. (When the green light is flashing on the Pi indicating CPU activity, the buzz changes.) I don't get the buzz from the headphones when plugged in, so I don't think it's coming from the sound card. The buzzing is also present in the speaker even if the audio is only going to the headphones. That leads me to believe that the Adafruit amp isn't filtering anything, or at least if it is, it's minimal, so I'm going to have to see if I can find any information on how to filter the noise and I also want to see how to incorporate the shutdown circuit into triggering when when I plug in the headphones.
            mooseprM T 2 Replies Last reply Reply Quote 2
            • mooseprM
              @obsidianspider yay for destruction! It's lots easier when you can unsolder one pin at a time.
              Love the scotch tape setup!
                @moosepr the tape was to make it easier to see what was going on in a photo and also to try to isolate audio from power wires due to that buzzing. Some reading is showing that I likely need some ferrite beads and that I should be using some resistors to bridge the stereo to mono, but it's 3:27 AM, so I should probably stop researching and go to sleep.
                mooseprM B 2 Replies Last reply Reply Quote 1
                • mooseprM
                  @obsidianspider maybe try powering the amp from a different source, see if that stops and buz?
                    backstander @obsidianspider
                    @obsidianspider
                    I don't know if this works but I read somewhere that you can edit /boot/config.txt and add the line "disable_audio_dither=1" and this should help with analog audio jack hiss issues. Worth a shot!
                    You might need to put a Ferrite Core on that cable. How it works: "magnetic materials absorb signal interference, reduce signal errors and improve signal integrity"
                      @moosepr That worked, but long term that's not a good solution since I am putting all this in a Gameboy case. I did try adding a capacitor to the power side of the amp, but that had no effect. I may need a specific size, I dunno.
                      I saw somewhere (I forget where now) that connecting A- to GND would help with the hiss, and it did tremendously. It's not perfect, but WAY better. I also haven't gotten to RadioShack yet to get some resistors for the bridging to mono yet.
                      @backstander I am definitely thinking that I'm going to need some ferrite beads at least, as they're showing up all over on sudomod. The trouble is that no one locally has them, so I'll have to order them online.
                      I tried the audio dither thing, but since the input source for sound to the amp is from the USB sound card that didn't help.
                      Off to RadioShack to buy some resistors!
                      • mooseprM
                        @obsidianspider it does sound like is picking up the interference through the power then. Maybe wrapping the power lines round a ferrite ring like @backstander mentioned will help? Do you have any old motherboards or anything knocking about? You can sometimes strike gold with the little copper inducters
                        curly
                          Some investigation into using capacitors to clean up electrical noise prompted me to try attaching a 0.1 µF capacitor to the power input of the amp. I can't tell how much it helped, but that combined with the 10-Ohm resistors coming off the headphone jack to bridge the stereo into mono has sound that has a level of hissing that I would say won't bring this project to a halt, but I am going to look into buying some ferrite beads to use on the power input as well as the speaker output to try to help clean things up a bit more.
                          Next up it's a matter of the two things I've been putting off: The power circuit (soft shutdown, low battery warning/shutdown) or modding the case...
                            thedudester80 @obsidianspider
                            Why would you need a sound card for a Pi 3? couldn't you just wire into the headphone jack pins and get the sound that way? Or is that not possible? Anyway the project is looking fantastic BTW. =]
                            Mint Boy, Case Arcade, New Projects Coming soon....
                              obsidianspider @thedudester80
                              @thedudester80 It's possible. I initially decided to use USB sound to try to reduce the hiss I was getting when I was doing some testing. The USB soundcard has zero hiss, and for how cheap it was, sounds really great with these old games. Considering that I'm getting some hiss with the Adafruit amp even with the USB soundcard as the source of the audio I'm not sure if it would be better or worse going right off the Pi. It might be worth trying things without the USB soundcard and saving that for my Gameboy Color project. I'll have to think about it.
                              And thanks for the kind words. This is a whole lot of figuring it out as I go, and I really have no idea what I'm doing.
                              mooseprM 1 Reply Last reply Reply Quote 1
                              • mooseprM
                                @obsidianspider ooooooh oooooooh oooooh lightbulb moment! Your currently powering the amp from the 5v input to the pi. What happens if you try powering the amp from the usb 5v output? Maybe that is cleaner?
                                obsidianspiderO 2 Replies Last reply Reply Quote 1
                                  @moosepr it's worth a try. The amp itself is rated to pull up to 800mA at full tilt, it I'm running a tiny speaker and the whole system is only going to be getting 1A from the PowerBoost, so the fact that the USB ports only output 500mA max shouldn't be an issue. I think what I'll try is tagging off the power that's connected to the sound card, at the sound card. Since they'll both be next to each other inside the case that would also cut down on wires in the case if this works. I'll report back, but first, some coffee.
                                    @moosepr Going to USB for power has basically eliminated the CPU/disk access related buzzing! I did leave the 0.1 µF capacitor in there, as I figured it can't hurt. There's still a little bit of hiss from the amp (just general background white noise when no sound is playing), but I'm thinking some ferrite beads on the speaker wires will take care of that.
                                    Now to read up on options for power circuitry…
                                      A Former User
                                      Up next: Pi in a DS.
                                        thedudester80
                                        I remember hearing something about using a capacitor for a hiss noise for your amp. I'm not sure what kind off the top of my head but it might be something to look into.
                                        • mooseprM
                                          moosepr @A Former User
                                          @itsnitro Hahaha, I have already thought of that one!
                                            A Former User @moosepr
                                            @moosepr Huh.
                                            But here's the thing; RetroPie needs to be compatible with 2 monitors.
                                            Cause ya know, the DS has two screens.
