    Kodi problems on retropie
    kodiproblemcontrollers
    13 Posts 3 Posters 3.8k Views
      DuckSalmon
      Raspberry pi3
      I have 2 problems when i run kodi
      I have the last versions of both of them, kodi and retropie
      The First problem is that if i have plugged my Joypad and it is activated, the kodi menu stucks on the Image option, and i cannot move the cursor because it return immediately on the First menu option
      The second one, when i plug an USB device, kodi cannot recognoze it and play movie...
      Please help me
      • herb_fargusH
        herb_fargus administrators @DuckSalmon
        @DuckSalmon wait til kodi 17 is out and has joypad support fixed. Otherwise you'll run into issues unless you know what you're doing. The details on setting up kodi configs are on the kodi wiki page.
          DuckSalmon
          I'll wait the next update
          But how about my problem to play my video files on a USB drive?
          Kodi seems to don't recognize or don't read my USB pen drive
          Edit: The USB drive can be open only for the First seconds after the plug it
          RascasR 1 Reply Last reply Reply Quote 0
          • RascasR
            Rascas @DuckSalmon
            @DuckSalmon If you can open the USB drive and than you "loose" it, it is most likely a power issue.
              DuckSalmon @Rascas
              @Rascas is there a way to resolve this problem?
              • RascasR
                Rascas @DuckSalmon
                @DuckSalmon You have to check if your power supply has enough current (amperes) for everything that you have connected to the Pi. Does your usb hard drive has a sepparate power supply?
                  DuckSalmon @Rascas
                  @Rascas is a USB pendrive
                  My raspberry now have plugged a USB keyboard , an USB Bluetooth dongle for my gamesir controller and this 8GB Pen drive
                  Now i try with an another USB pendrive
                  • RascasR
                    Rascas
                    How much amperes does your power supply have? And why are you using a bluetooth dongle when the Pi 3 has bluetooth builtin?
                      DuckSalmon @Rascas
                      @Rascas I have the official 0.5 A raspberry power supply
                      My controller doesn't pair without it:(
                      • RascasR
                        Rascas @DuckSalmon
                        @DuckSalmon The offiicial power supply has 2.5A. If yours have only 0.5, that's the problem.
                          DuckSalmon @Rascas
                          @Rascas
                          Sorry it has 2.5A
                          I read input instead of output
                          • RascasR
                            Rascas
                            If it really is the official power supply, that shouldn't be the problem. Normal Kodi doesn't have automount, only kodi-standalone. Either launch kodi-standalone in terminal or mount your drive manually and see if it works.
                              DuckSalmon @Rascas
                              @Rascas
                              Now after a quick format my USB works
                              Cannot understand the reason but i'm happy that now works:)
