    8BitDo NES30 Pro N64 Not saving
    8bitdon64save file
    4 Posts 3 Posters 2.0k Views
    • E
      eekfonky
      I have my configuration as follows but on N64 roms (Mario 64 for example) on RetroPie version 4.0.6. When I hit select+L1 nothing happens
      Pi Model: 3
      RetroPie Version Used: 4.0.6
      Controller used: 8Bitdo NES30 Pro
      Error messages received:
      Guide used: https://github.com/libretro/retroarch-joypad-autoconfig/tree/master/udev
      File: /opt/retropie/configs/all/retroarch-joypads/8BitdoNES30Pro.cfg
      Emulator: mupen64plus-GlideN64
      #8Bittdo.com - Firmware v1.71 (2016-09-06)
      input_driver = "udev"
      input_device = "8Bitdo NES30 Pro"
      input_device_display_name = "8Bitdo NES30 Pro BT(POWER)"
      # Hex vid:pid = 3820:0009 -> Decimal vid:pid = 14368:9
      input_vendor_id = 14368
      input_product_id = 9
      input_b_btn = "1"
      input_y_btn = "4"
      input_select_btn = "10"
      input_enable_hotkey_btn = "10"
      input_start_btn = "11"
      input_exit_emulator_btn = "11"
      input_a_btn = "0"
      input_x_btn = "3"
      input_l_btn = "6"
      input_r_btn = "7"
      input_l2_btn = "8"
      input_r2_btn = "9"
      input_l3_btn = "13"
      input_r3_btn = "14"
      input_r_x_plus_axis = "+2"
      input_r_x_minus_axis = "-2"
      input_r_y_plus_axis = "+3"
      input_r_y_minus_axis = "-3"
      input_b_btn_label = "B"
      input_y_btn_label = "Y"
      input_select_btn_label = "Select"
      input_start_btn_label = "Start"
      input_a_btn_label = "A"
      input_x_btn_label = "X"
      input_l_btn_label = "L1"
      input_r_btn_label = "R1"
      input_l2_btn_label = "L2"
      input_r2_btn_label = "R2"
      input_l3_btn_label = "Left Thumb"
      input_r3_btn_label = "Right Thumb"
      input_r_x_plus_axis_label = "Right Analog Right"
      input_r_x_minus_axis_label = "Right Analog Left"
      input_r_y_plus_axis_label = "Right Analog Down"
      input_r_y_minus_axis_label = "Right Analog Up"
      # Bluetooth Mode(POWER) D-pad = Buttons and Left Analog = Joystick.
      input_up_btn = "h0up"
      input_down_btn = "h0down"
      input_left_btn = "h0left"
      input_right_btn = "h0right"
      input_l_x_plus_axis = "+0"
      input_l_x_minus_axis = "-0"
      input_l_y_plus_axis = "+1"
      input_l_y_minus_axis = "-1"
      input_up_btn_label = "D-Pad Up"
      input_down_btn_label = "D-Pad Down"
      input_left_btn_label = "D-Pad Left"
      input_right_btn_label = "D-Pad Right"
      input_l_x_plus_axis_label = "Left Analog Right"
      input_l_x_minus_axis_label = "Left Analog Left"
      input_l_y_plus_axis_label = "Left Analog Down"
      input_l_y_minus_axis_label = "Left Analog Up"
      I added the;
      from another configuration to see if that would help. I can now exit with SAVE+START, but cannot save with the usual LEFT shoulder + SELECT and load with RIGHT shoulder + SELECT
        BuZz administrators
        https://retropie.org.uk/forum/topic/3/read-this-first (ps you need to use formatting on your post)
        • E
          eekfonky @BuZz
          @BuZz Sorry, sorted formatting. See above
          • FloobF
            Floob
            It looks like you are referring to retroarch.cfg based controller configs (to generate those I'd let ES do it, not the manual way it looks like you have.)
            Also, you can see here that the emulator you are using wont use those config files:
            https://github.com/retropie/retropie-setup/wiki/Nintendo-64
