    Light still on after shutdown
    13 Posts 5 Posters 5.7k Views
      BuZz administrators @glennlake
      @glennlake https://github.com/raspberrypi/firmware/commit/b2ee39c7a6dc8a73ee7b559c7a833271eb10ca11
      glennlakeG 1 Reply Last reply Reply Quote 2
      • glennlakeG
        glennlake @BuZz
        @BuZz Thanks!! I hadn't found this yet. Good job.
        • Q
          quentuus
          This post is deleted!
          • CharcoC
            Charco
            How do you update the firmware?
            FinheadF 1 Reply Last reply Reply Quote 0
            • FinheadF
              Finhead @Charco
              @Charco said in Light still on after shutdown:
              Hit F4 to get to command line and follow these steps
              • Q
                quentuus
                • Q
                  quentuus
                  if one day the link above will be dead
                  (we all know this day will come)
                  , here's the code to update the firmware:
                  sudo apt-get update
                  sudo apt-get dist-upgrade
                  • Q
                    quentuus
                    but even with the firmware update, both lights still blinking...
                    • CharcoC
                      Charco
                      Thanks guys :)
                        BuZz administrators
                        You will need to wait until that version of the firmware is packaged up (Unless you want to risk using rpi-update)
