    SNES scraping not working/not saving- every other ROM works perfectly
    snesscraping
    11 Posts 2 Posters 4.1k Views
      BuZz administrators
      please provide more details on your set up as agreed when registering on the forum - https://retropie.org.uk/forum/topic/3/read-this-first
        s_purs
        Sorry, I have amended the first post. Feel free to delete this one and your one.
          BuZz administrators
          Do you have "Save metadata on exit" switched off in Emulation Station ?
          Not sure why snes isn't working for you using sselph's scraper - can you share your settings for that scraper ? Did you try switching database source ?
            s_purs
            I have tried every variation of them. Having save on and off. I have tried all the different source, doing images only, doing everything, replace existing Gamelists or appending. Any option available to change inside and outside of Emulationstation in scraping I have tried doing it on and off. All of this is weird as it works fine outside of Emulationstation for all of the other types of ROMs.
            The best outcome I have had is in Emulationstation it will search and find all the images/data but then loses it after. That's why I am trying to search where it stores that information temporarily (as it doesnt change the Gamelists file in the proper location) as then I can make a copy of that data and manually add it in the right location.
              s_purs
              The other option is if anybody wouldn't mind sharing me their Gamelist file (just that .xml not the actual ROMs or anything) for SNES then at least it would hopefully link up some of my images with the ROMs- some is better than nothing! Would be really grateful for a couple of Gamelist files I can play with :)
                BuZz administrators
                Please can you be more specific and share your sselph scraper settings as things like "every variation" doesn't help - every variation of what ? Scraping in ES and scraping using the scraper in retropie-setup are two separate things (two different programs).
                save meta data on exit should on on if scraping in emulationstation. However if you scrape using sselphs scraper and get it to scrape to the roms folder, this will override any scraping from within ES - you would need to remove the gamelist.xml and images from the roms folder to use the ES scraper after this.
                  s_purs
                  When I say every setting, I literally mean I have gone through every setting in both scraping programs and none of them seem to work for it.
                  https://github.com/retropie/retropie-setup/wiki/scraper
                  Going through these screenshots outside of Emulationstation I have:
                  First updated to the latest scraper then,
                  Tried scrape all systems
                  Scrape chosen system
                  Thumbnails only enabled and the other 2 options in there
                  Scraper databases I tried both
                  ROM Names I tried all 3 options
                  Gamelists I tried ovewrite and append
                  In EmulationStation I:
                  Changed the scrape from databases
                  Kept ratings on
                  In scrape now I changed the Filter and went through every option
                  System I have tried all and just SNES
                  User decides on conflicts I turned off
                  And I also tried the saving on exit on and off.
                  I have also tried removing the blank Gamelists from both locations (default and ROM folder) and also added 1 game of my own and then tried appending the other ones to it.
                  The only thing I haven't tried is Sselphs Scraper Advanced Configuration to scrape my own images as I would like to have the descriptions and stuff, but that would be the final option I have to consider if I cant get this working or can't get someone to share their SNES gamelist.xml
                    BuZz administrators
                    Did you remove the blank gameslists when ES was not running ?
                    Starting with snes please can you confirm exactly which paths you removed the gameslists from before you tried to scrape with the external scraper ? I need to be able to reproduce the problem to advise.
                    I suspect you have missed a path or an option is set wrong. Please also confirm what settings you are using right now, so I can test.
                      BuZz administrators
                      Did sselph's scraper output anything when it ran ? Make sure you have it in "overwrite" mode also.
                        s_purs
                        OK here are two brand new tests, with the exact settings and steps I am using:
                        Exited Emulationstation and tried the scraper with default settings and it still didnt do anything- it instantly says complete.
                        I then deleted the gamelists from both folders whilst emulationstation was closed.
                        Ran the scraper in emulationstation again and this time it outputted a file which I could use. The only difference I did this time was made sure emulationstation was closed when I deleted the files- I thought I had done that before but maybe I hadnt and that was the difference.
                        Weird that it doesnt work outside of emulationstation just for the SNES and weird that it just worked this time- I had tried for 2hours constantly trying different settings/combinations of trying to do it before. No idea why it worked this time but it worked so I'm happy now!
                        Thanks for your advice
