    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 877.0k Views
      Aksen @screech
      @screech Can there be an option to scrape metadata but skip the image? I'd like to re-scrape at some point, because some of my scraped metadata was in french.
      • screechS
        screech
        @Aksen
        Normally the basic option do that :
        Recreate the XML, but if picture exist, don't touch it... Can you give it a try?
        @mattrixk
        Just release a new version : You can now put a size for every media you download (in the standard profil)
        (Need to see for sys info/media now...)
        Some new things added :
        You can now add Genre Picto in the Mix
        You can now put some text in Mix
        You can now rotate picture in Mix
        Lot's of correction on the fallback function (some pictures doesn't download exemple : 2DBox in standard profil now work nice ;) )
        Added a Mirror server to avoid main server instability. (automatique fallback)
        The Wiki is up to date with the new function for MIX : https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/wiki/[TUTO]-Making-a-MIX-Template
        mattrixkM 2 Replies Last reply Reply Quote 2
        • mattrixkM
          mattrixk @screech
          @screech You're a legend. Hopefully I'll get the chance to try this out today or tomorrow.
          • mattrixkM
            mattrixk @screech
            @screech I downloaded the latest version, but when I try to run it I get this error:
            Universal XML Scraper fatal error !
            (Time Out)
            Edit: I'm on a Windows 7 PC.
            Edit 2: I just realised it could be because screenscraper.fr is down. It would be nice if I could still play with the program, even if the website isn't working. I could keep working on Profiles without actually scraping, even if the website was down.
            I just tried the previous version (v2.1.0.3) that worked yesterday. It doesn't work at the moment either.
            fergyzF 1 Reply Last reply Reply Quote 0
            • fergyzF
              fergyz @mattrixk
              @mattrixk at least you confirmed I'm not crazy... i get the same error.
              • mattrixkM
                mattrixk @fergyz
                @fergyz yeah, I'm pretty sure it's because the website is down.
                @screech, is it possible to open the program when the website isn't working? I had the idea of creating a MIX Profile to smush Local images into a single image.
                Eg: Say I have 5 games in a system, and for each game I've already used a Scrape Profile to download Wheel, 3D Box Art and Screenshot, and suffixed each image with "-wheel", "-boxart" and "-screenshot" respectively.
                Can I use UXS to format each of these images into a single image per game? Or maybe have a Scrape Profile that downloads the images separately, but also Mixes some of them together? That would be awesome.
                E 1 Reply Last reply Reply Quote 1
                • E
                  EctoOne @mattrixk
                  Oh yeah, a tool to Mix offline images would be great. I spend so much time doing that manually for some rom hacks and when the Database was kinda empty in the beginning and I had to grab images from other sources.
                  BTW @mattrixk Can you upload the Mix Profil that you made to get all the single images or post the code somewhere?
                  • mattrixkM
                    mattrixk @EctoOne
                    @EctoOne
                    This is a WIP Scrape Profile for UXS.
                    http://pastebin.com/bZNYQ29h
                    It downloads screenshots, 3d box art (with 2d box art backup), fan art, game logo (wheel art), game cartridge (media) and game video. It saves them all to the 'downloaded_images' folder with suffixes of "-screenshot", "-boxart", "-fanart", "-logo", "-media" and "-video" respectively.
                    It also puts each of them into a gamelist.xml in <screenshot>, <boxart>, <fanart>, <logo>, <media> and <video> tags respectively.
                    It downloads each element as large as it can, up to 1024x1024 (videos will pretty much always be 640x480, as will screenshots, as that is the size of them within screenscraper.fr).
                    To use the Scrape Profile, save the xml as downloadeverything.xml (or whatever you want to call it), then put it in the "ProfilsFiles" folder within UXS. You can then choose it from the Scrape Profile menu.
                    Keep in mind that Scrape Profiles and MIX Profiles are 2 different things (something it took me a while to understand. I was confused as balls until I did, but once I did, it made things much easier).
                    Scrape Profiles are for scraping individual elements. MIX Profiles scrape the elements and combine them into a single image.
                    Once again, this is a work in progress, so I take no responsibility for your computer blowing up, or aliens abducting your loved ones.
                    • screechS
                      screech
                      Sorry, it's impossible to launch UXS without a net connexion to the website... Too much problem after that...
                      But I have in my pretty big todolist : Make a MIX Generator soft ^^
                      Where you can scrape 1 game (with all the media/data it is possible) and create a MIX with them...
                      But it's a project nearly as huge as UXS >< so it's not for now ;)
                      If I can, I will try to make a "light" version of that ;)
                      • mattrixkM
                        mattrixk @screech
                        No worries @screech. Love your work.
                        • screechS
                          screech
                          Hi, the new 2.1.0.5 just come out.
                          A lot's of change :
                          • Corrected :
                          ° Better stability on downloaded images (Some never download :S and miss in the MIX)
                          • Added :
                          ° Dynamique Handle to API server, now I can force the server to ask (for the futur when we have a fallback server ;) or country based server )
                          ° Lot's of new Picto media (Nb of player, Notes, Classification, Editor, Developer, Genre) -> Beta it can change soon.
                          ° Added 3 news MIX Template for Bigshot Theme with these new picto (1 is directly on local, the 2 other are on the repository, you can download them directly from UXS)
                          • WARNING Added things that can "broke" you existing MIX Template
                          ° You need to put the full Xpath to the Source_Value node (exemple : Game need to start by 'Data/jeu/' and System by 'Data/systeme [id="%IDSYSTEM%"]')
                          ° The CENTER/LEFT/RIGHT/UP/DOWN function in Target_TopLeftX, Target_TopLeftY (and other) now take the "origin" point of the picture (default are TopLeft corner of the Picture)
                          ° You can now use Target_OriginPicX and Target_OriginPicY to fixe the origin point of the picture. So now to center a picture you need to put :
                          • <Target_TopLeftX>CENTER</Target_TopLeftX>
                          • <Target_OriginPicX>CENTER</Target_OriginPicX>
                          • <Target_TopLeftY>CENTER</Target_TopLeftY>
                          • <Target_OriginPicY>CENTER</Target_OriginPicY>
                          (The Origin point of the picture will be the center, and we center this origin point to the final picture)
                          This is exemple of the New MIX for BigShot Template :
                          text alternatif
                          text alternatif
                          text alternatif
                          mattrixkM 1 Reply Last reply Reply Quote 1
                          • mattrixkM
                            mattrixk @screech
                            This is huge. Great work @screech!
                              a7mag3ddon
                              Is it possible to use this scraper on roms folder on the PC hard drive instead of on the Pi itself? I have a backup of my pi roms folder on the PC so want to run it on that instead.
                              • mattrixkM
                                mattrixk @a7mag3ddon
                                @a7mag3ddon you can download the 32 or 64 bit version of the scraper here and run it on your PC. It's what I use to build scrape and mix profiles. (I don't even know how to use it on the Pi itself shhh, don't tell anybody).
                                  a7mag3ddon @mattrixk
                                  @mattrixk
                                  Sorry i didnt explain, i have it for PC but i want to scrape FOLDERS on my pc instead of on the PI :-)
                                  mattrixkM daeksD 2 Replies Last reply Reply Quote 0
                                  • mattrixkM
                                    @a7mag3ddon Oh, sorry. It's late and I've had a big day. I can't really brain at the moment, I have the dumb.
                                    • screechS
                                      screech
                                      Just to inform you I just release a new version with a little change on Retropie Profil.
                                      No more (Video) profil. Now you can add Marquee and/or video (+ the standard "image") juste with a litle configuration in the "Option configuration menu" ;)
                                      @a7mag3ddon Of course you can scrape a folder on your PC, USB Key, external hardrive, network drive, or directly to the PI ;)
                                      My advice : choose a Retropie Profil with [ROM FOLDER] in the name ;)
                                      So Gamelist and downloaded_image folder will be put in the "rom folder" ;)
                                      when selected (use the wizzard), just select the "main" folder with all the subfolder to the plateform rom. Then use the autoconfig ;)
                                      • daeksD
                                        daeks @a7mag3ddon
                                        @a7mag3ddon share your local folders as "roms" and "configs" and add "\\yourpcname\roms" to the scraper as path. Works fine.
                                          a7mag3ddon
                                          Ooohhh thanks! I think it will be quicker, and i dont have to have the Pi on for days when my pc is already on anyway.
                                          Can i also ask. will it put the files and gamelist in the folder with them like it does on the pi?
                                          • screechS
                                            screech
                                            On retropie, you have to way to handle the Scrape :
                                            What I call the "easy" one ;) All in the rom folder :
                                            Exemple :
                                            In your Rom/Snes/ you have
                                            • your roms
                                            • the gamelist.xml
                                            • the downloaded_images folder (with all the picture in it).
                                            If I don't mistake, it's the first place where emulationstation check for these info.
                                            But it's not compatible if you scrape with the Retropie Scraper.
                                            And the good thing, it's easily transportable.
                                            So, for UXS, the "[Rom folder]" profile are these one.
                                            The second way is the "standard" way Retropie default folder.
                                            • Your roms are in : /home/pi/RetroPie/roms/%system%/
                                            • Your gamelist.xml are in : /home/pi/.emulationstation/gamelists/%System%/
                                            • Your picture are in : /home/pi/.emulationstation/downloaded_images/%system%/
                                            So, for UXS, the "standard" profile are these one.
