    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 899.6k Views
    • SquilenatorS
      Squilenator @screech
      @screech Nintendo NES
        Jeck11
        I just downloaded from the github and my Windows Defender registered a couple hits from it: 0_1486475237403_2017-02-07 08_45_51-Windows Defender.png
        Anyone else noticed anything weird?
          Dukafleed
          screech, i have been using your tool for sometime and i can say it is the best artwork provider (specially the 3 in 1 feature)
          are you looking to expand itin include a rom metadata manager where you can fetch info and edit them accordingly by rom or roms ?
            BORIStheBLADE1
            OK so with version 2.1.0.5 I was able to scrap all my rom sets and every thing came back 100%. I updated to 2.1.0.6 and it wouldn't scrap the same rom sets 100%. Also every other time I'd try to use it, it would say something about losing connection. So I have reverted back to 2.1.0.5 and everything is working right again.
            • hooperreH
              hooperre @Tasio
              @Tasio
              • I think creating files and folder when first lunch may not be a good idea unless you ask for confirmation, many pleople try to open open downloaded software from the browser.
              If I may add something specific... I think overwriting the XML file without confirmation is quite detrimental and, if not backed up, can cause a major headache for anyone who has done video set ups and things of that nature.
              4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
              • hooperreH
                hooperre
                I'm wondering a way to get specific files that were missed. When I first downloaded roms (as a 10 year old 10 years ago) I renamed everything because I didn't understand why there were (rev a) or (USA) or (U)'s attached in the romsets. I just wanted 1 game with an easy title. So a few (overall it did a great job identifying my games) games were not picked up. One that doesn't make much sense to me is Donkey Kong Country 2 and 3. I'll use DKC3 as my example.
                My file name is simply: "Donkey Kong Country 3 - Dixie Kong's Double Trouble.zip"
                So I went to the game page on screenscraper.fr and created a fake new (text) file and renamed it one of the 'Associated File Names' directly from the file name section: "Donkey Kong Country 3 - Dixie Kong's Double Trouble! (USA) (En, Fr) .zip" and "Donkey Kong Country 3 - Dixie Kong's Double Trouble! (USA) (En, Fr) .sfc". (File extension was correct, not just renamed with a .txt extension.)
                Re-ran the scraper and no luck. This method did work for Mega Man 8 and Dragon Ball Z - Hyper Dimension, however. Is there some trick to this that I'm missing?
                • hansolo77H
                  hansolo77
                  I think the scraper will use rom name only as a last resort, and will use a hash check first. The hash shouldn't have changed if the name is all that has.
                  Who's Scruffy Looking?
                    davidgrohl Banned
                    Hi,
                    I would to try this program with retro pie running on raspberry pi 3.
                    Is it possibile to scrap my roms and transfer result on retropie?
                      Tasio @hooperre
                      @hooperre what worked best for me was getting the missing roms from a good source.
                      • FlyingTomahawkF
                        FlyingTomahawk
                        Notebook: Acer, i5, 4GB RAM etc...
                        OS: Windows 7 64-bit
                        Downloaded this form github into my downloads folder.
                        Extracted there and tried to run the program with either Scraper64.exe or Scraper.exe but nothing happens, nothing loads, no process is started.
                        Looking at the task manager there is no indication that this program was started.
                        Deactivated firewall and anti-virus software, still no luck.
                        Did I miss a step?
                          paradadf @FlyingTomahawk
                          @FlyingTomahawk why do some people doesn't look into the releases page like in almost any other project?
                          https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/releases
                          FlyingTomahawkF 1 Reply Last reply Reply Quote 0
                          • FlyingTomahawkF
                            FlyingTomahawk @paradadf
                            @paradadf
                            Lesson learned, thank you.
                            • FlyingTomahawkF
                              FlyingTomahawk
                              @screech
                              Fantastic work!
                              Just played around with it and it is not only fast but also gives you tons of options.
                              I like the MIX images thing that looks really awesome.
                              I just tested this on my PC but I will have to trash all my images and gamelists on my 2 RPis and replace them with this stuff here.
                              Again thanks a lot for this.
                              • FlyingTomahawkF
                                FlyingTomahawk
                                After 6 hours and 54 minutes scrapping I have 820 Images and.... an empty gamelist.xml file. :-/ lol
                                I don't think it can handle more then a few roms at the time. I am trying now half of that amount to see if it'll work this time.
                                I'll know more in 3 hours and 3 minutes...
                                  Dochartaigh
                                  I could have totally missed this, but I'm coming from a Mac and installed Parallels so I can use PC programs. To get this scraper to work your Windows PC needs to be able to see the Pi as a network drive, correct? How are you guys doing this?
                                  On my Mac it's not setup as a network drive either - I either SSH in with the built-in Mac Terminal program, or use my FTP program (Cyberduck or FileZilla)...just seeing how you PC users would go about this the best way. All my searches are bringing up how to run ROMs from a Network drive - when I want to go the opposite way (view the Pi as a Network drive in Windows, not have the Pi see a network drive in PC/Windows land).
                                  • FlyingTomahawkF
                                    FlyingTomahawk
                                    I have Emulationstation setup on Windows with the exact same system setup and roms as on my RPi. I then scrape the roms on PC (RetroPie roms MIX) by selecting the paths that are setup in Emulationstation PC.
                                    And once done I adjust the paths inside the gamelist.xml file to match the folder structure of my RPi and then transfer the images and gamelist.xml files via network access to the RPi.
                                      paradadf @Dochartaigh
                                      @Dochartaigh sadly, UXS doesn't work on a virtual machine. Or at least, nobody has been able to make it work (yet).
                                        Dochartaigh @paradadf
                                        @paradadf said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                                        Parallels isn't like a traditional virtual machine per se, it's using the mac's Bootcamp Windows (10) partition so you can run ANY Windows program as if you were running Windows diretly (including Universal XML Scraper).
                                        ...I just need to know how you guys are using Universal XML Scraper. Ignore that I'm on a Mac. How do you setup your Pi as a network drive in Windows? -- that's what needs to be done correct to get it to work, correct? I'm watching YouTube videos now so all will become self evident I'm sure...(maybe ;)
                                        EDIT YouTube seems to say that RetroPie automatically shows up as a network drive in Windows if they're both connected to the same network? If so that would be the first time Windows makes something easier to use than my Mac ;) ...booting up now to see if I've missed that drive in Windows Explorer and will try to run the scraper (going to try the cool 3-image "MIX" option).
                                          Tasio @Dochartaigh
                                          @Dochartaigh not sure if this is answering your question but to access the retropie shared folder on windows, type this address on the file explorer: "\retropie" without the quotes, if is not working use the IP address instead of "retropie"
                                            Dochartaigh @Tasio
                                            Got it to work thanks.
                                            Question: one of the biggest draws of this is that it's supposed to be faster than EmulationStation and SSelph's super-slow scrapers, right?
                                            Why would it STILL take 8+ hours to scrape the No-Intro NES/Nintendo romset? Tried on both my Mac, and on a proper Windows 10 system. We're also talking a quad-core i7 processor with 16gb of ram, and an internet connection topping 135 mb/sec...
                                            Even if I pay the 10 Euro fee for the scraper site where I can scrape 5 at once (that's a real thing, right? not some scam I saw on a couple YouTube videos, correct?) We're still looking at probably 24+ hours for my entire rom collection (Atari 2600/7800, master System, TG16, NES, SNES, Genesis, GB, GBC, GBA, Arcade, etc.).
                                            Am I missing something?
