    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 873.7k Views
      MartinS
      I donated £10 to have access to 5 threads. Anyone know how to activate this? I logged in and it says I have access to 1 thread. Thanks.
        paradadf @MartinS
        @MartinS join them on IRC on:
        https://kiwiirc.com/client/irc.freenode.net/#screenzone
        And tell anyone there that you donated. They'll ask you for your user name and you are ready to go!
          MartinS @paradadf
          @paradadf Thanks. I will try that now.
            tekn0 @MartinS
            @MartinS Same thing here, just hangs and does nothing. Auto configuration seems to work fine. I am only trying to scrape a single system.
            • screechS
              screech
              Sorry to be late :S (christmas and familly duty)
              Ok, There is a problem with my last change on SSH command :S I'll correct that in the version I release today ;)
              (For the other error : it's due to the server migration. Normally all is ok right now ;) )
              T 1 Reply Last reply Reply Quote 2
                tekn0 @screech
                @screech said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                The new updated fixed all of the issues for me, thank you very much. :)
                Also is there a list that tells what the "profiles" are? I don't understand the difference between
                Retropie (Mix) and Retropie [Rom folder] (Mix)
                • V
                  vric
                  Last night, I was using the scraper for the whole night (full system scrap). After getting up this morning, I saw the software crashed and did about 30% of the job. Nothing updated on retropie.
                  Now I try to restart the software, but everytime I get an "Universal XML Scraper fatal error! (err_SystemList)
                  Tried rebooting, redownloading, deleting settings files, still can't get the software to launch anymore.
                  Any idea ?
                    detron
                    @vric
                    I just started using this scraper yesterday, and everything seemed fine, I tried to run it this morning, and I get the same error.
                    SpaceSocksS 1 Reply Last reply Reply Quote 0
                    • SpaceSocksS
                      SpaceSocks @detron
                      @detron I also am having the same problem. Started to scan all systems last night and woke up it only did afew systems. when i restarted the XML Scraper it gave me that "Universal XML Scraper fatal error! (err_SystemList).
                      Now I cant even run the program to finish scraping.
                      • SpaceSocksS
                        SpaceSocks @SpaceSocks
                        @SpaceSocks Yea I just reimaged my Pie SD Card Fresh Install. Redownloaded Universal_XML_Scraper64.exe. Still get the "Universal XML Scraper fatal error! (err_SystemList) error at program launch. cant even run it :/
                        • SpaceSocksS
                          @SpaceSocks I tried to create a new Thread In Help & Support but i wasn't able to. Someone else think this is a good idea?
                          • SpaceSocksS
                            @detron @vric I started a new Thread for this Problem in Help & Support -
                            https://retropie.org.uk/forum/topic/6920/universal-xml-scraper-fatal-error-err_systemlist
                            • hansolo77H
                              hansolo77
                              I experimented a bit yesterday with the Scraper and using the MD5 hashing for Sega CD. It seemed to work, but gave a timeout error after every single file. Maybe it wasn't really working, and the results it found was through a name search.
                              Who's Scruffy Looking?
                              • L
                                Lok
                                Hello
                                I can't make it work sadly.
                                The ES is well killed (I presume) , paths are correct (I choosed the rom path for gamelist and downloaded images) but here is the result of scrapping :
                                This is for n64 but it's the same for all systems
                                Do you know what I'm doing wrong ?
                                Thanks.
                                • SpaceSocksS
                                  SpaceSocks @Lok
                                  @Lok i have the same problem
                                  • L
                                    Lok @SpaceSocks
                                    @SpaceSocks
                                    Ok, I've read the thread you opened. If you sign up for free at http://www.screenscraper.fr it will work.
                                    Thanks by the way.
                                    • RambytesR
                                      Rambytes
                                      Same problem... 3 days now and I cannot scrap my rom into Retropie with the Universal Scraper...
                                      What the problem???
                                      • screechS
                                        screech
                                        Sorry.
                                        We migrate both server and new website/db version at the same time...
                                        And it wasn't a good Idea at the end of year (a lot's of new user)
                                        So we had massive request on the new server aren't really ready for such a huge number of scraper..
                                        We are working hard to gain back stability. And it seems it's going well today.
                                        I can go back to UXS and correct some "new" probleme introduced with the new version..
                                        But for information, the new DB allow more things and new data / media so you can see very soon the new improvement... (exemple : we already have some Brazilian media, and now UK isn't the same as US)
                                        Thank you for your patience. We are doing what we can ;)
                                          dirty_horror
                                          Are you guys running the scraper from a virtual machine? I had this problem using the app on windows 10 on my mac with VMware fusion. I just now tried running it from my real PC and it's working perfect.
                                          • N
                                            Nismo @hansolo77
                                            @hansolo77 said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                                            @vbs If that's the case, I'll just stick with my current batch of scrapes until Carbon is updated to allow videos. Because I have a bunch of systems installed on my RetroPie, I pretty much have to use Carbon. I don't like it, but it's the only theme that seems to work.
                                            Carbon theme with video support:
                                            http://www.mediafire.com/file/f32kjrkeopykjra/carbon_with_video.zip
                                            Enjoy.
                                            hansolo77H 1 Reply Last reply Reply Quote 1
