    NEOGEO Scraper Problems Please Help
    neogeoscraperretropie
    8 Posts 3 Posters 3.1k Views
      KingVarus
      Hello,
      i build my own RetroPie Gaming Console out of Wood, i completed it today.
      Sadly i cant get scraper to find the metadata for some games. BlazingStar Spinmaster TopHunter and Windjammers.
      Somehow it found all the Pictures for the MetalSlug Games.
      Please Help, before my OCD kills me
      • rbakerR
        rbaker @KingVarus
        @KingVarus Avoid the built in scraper and use the mighty Selph....
        https://github.com/retropie/retropie-setup/wiki/scraper, worked for me. Follow instructions for MAME.
          KingVarus
          This post is deleted!
            KingVarus @rbaker
            @rbaker Tried both, neither do work
            • rbakerR
              rbaker @KingVarus
              @KingVarus I suggest you compare what you did against this video......
                KingVarus @rbaker
                @rbaker i dit it that EXACT same way.
                I tried it again like 5 seconds ago, NOW i have all the metadata except for SNK vs capcom. I think you gotta try it a few times, sometimes it works, sometimes it does not.
                • rbakerR
                  rbaker @KingVarus
                  @KingVarus The databases can go offline on occasion.
                  • screechS
                    screech
                    If you have a windows PC, you can try this : https://retropie.org.uk/forum/topic/5291/soft-universal-xml-scraper-v2-easy-scrape-with-high-quality-picture ;)
