    Theme Help!
    help and suppornoobretropie
    2 Posts 2 Posters 1.9k Views
      tymo614
      Hello! To start, I literally just got done building my first RetroPie on my first Raspberry Pi 0. Now, I was looking around in the settings and saw the theme thing. I hit install (there is no WifI) and noticed nothing changed. I thought I had to uninstall the current theme, so I did. Now there's no theme at all and it looks so barren. And hideous. Anybody know how to install any of the themes via USB? Thanks!
      Note: I cannot take apart or rebuild the RaspberrY Pi due to what I did to it. Thanks!
        dudleydes @tymo614
        @tymo614 RetroPie themes are stored on Github repos so you can download a zip, extract it and copy it to your USB stick. If you wish to restore the default Carbon theme, then you can download it at: https://github.com/RetroPie/es-theme-carbon
        Once you have the theme on your USB stick, then place the es-theme-carbon-master folder in the /home/pi/.emulationstation/themesfolder on your pi. When you restart EmulationStation, the theme should be available under UI settings in the ES menu.
        You can find many of the themes at the RetroPie Github page: https://github.com/RetroPie, themes repos begin es-theme-{name of theme}.
        If you can't find a theme, then you can check the source here and google for it.
