    ARB_texture_non_power_of_two: MISSING
    emulationstatiostart
    5 Posts 3 Posters 2.3k Views
      Cirelli94
      I'm using an old PC
      RetroPie Version Used: 4.1 git cloned from github
      Built From: on top of Ubuntu 16.04 server with lubuntu-core installated
      Error messages received:
      From es_log.txt:
      lvl2: EmulationStation - v2.0.1a, built Nov 28 2016 - 09:51:00
      lvl2: Creating surface...
      lvl2: Created window successfully.
      lvl2: Checking available OpenGL extensions...
      lvl2: ARB_texture_non_power_of_two: MISSING
      Guide used: https://github.com/RetroPie/RetroPie-Setup/wiki/RetroPie-Ubuntu-16.04-LTS-x86-Flavor
      I've installed from menu of retropie_setup.sh and made basic install.
      After do-not-know-how-many-hours it end!
      So I did emulationstation via cli and it just doesn't start anything!
      So i checked es_log.txt (above reported) but I don't know what to do!
      Thank you very much in advance!
        BuZz administrators
        Please be more specific about system (eg cpu / gpu etc) and version of RetroPie.
        Also please post the output from /opt/retropie/supplementary/emulationstation/emulationstation --debug (please format it in a code block - http://commonmark.org/help/)
        • Z
          Zigurana @BuZz
          @BuZz : that needs to be two dashes (no spaces) at the end there, or not?
          So [path]/emulationstation --debug
            BuZz administrators @Zigurana
            @Zigurana indeed. thanks. typo :-)
              Cirelli94
              Thanks mates for your help!
              Hardware specifications
              RetroPie version: if i "git log" inside my repo I obtain:
              * commit 88829054bf0cc54d5779704ac3e3c41a2d1eb1a0 (grafted, HEAD -> master, origin/master, origin/HEAD)
                Author: Jools Wills <buzz@exotica.org.uk>
                Date:   Sat Nov 26 18:21:55 2016 +0000
              I downloaded it via git clone https://github.com/RetroPie/RetroPie-Setup.git
              Should I download https://github.com/RetroPie/RetroPie-Setup/archive/4.1.zip and install from that source?
              /opt/retropie/supplementary/emulationstation/emulationstation --debug output:
              cirelli@ubuntu:~$ /opt/retropie/supplementary/emulationstation/emulationstation --debug
              emulationstation: ../../../../../../src/mesa/drivers/dri/nouveau/nv10_render.c:104: get_hw_format: Assertion `0' failed.
              Aborted (core dumped)
              One more thing! If I ssh to the pc I installed RetroPie to... Emulationstation START !!! :) But it isn't what I would obtain.. :) :) :)
