    Start emulationstation with ssh
    sshubuntu
    17 Posts 9 Posters 16.7k Views
      Gul
      Howdy community,
      Let me start by saying im a linux novice, but i got a intel nuc with xubuntu working.
      Now im having a hard time finding the answer to my question. I'd love to start emulationstation with an ssh command from my cellphone.
      I dont have a keyboard attached to my setup so the regular command line is not an option. I also use my setup for other purposes so i'd rather not autostart emulationstation when i boot up.
      When i try the regular emulationstation command in ssh i get an error that there is no display.
        backstander @Gul
        @Gul
        I'm not sure if this will work in Xubuntu but I believe this is how you accomplish this on an actually Raspberry Pi:
        nohup emulationstation &
        I remember have trouble doing something like this many many years ago and I vaguely remember using something like DISPLAY=:0 to tell it to launch on X windows.
          Gul @backstander
          @backstander
          Hey, ive made a script with your input :
          export DISPLAY=:0
          This seems to be working so far. Thanks :).
            chronics
            This works for me in as far as I can start emulationstation but once I try to actually start a game I just get a black screen. Playing around with some of the XDG environment variables to see if that makes a difference.
              jmpv85
              I have exactly the same behaviour... have you found anything? I'm stuck on this.
              Thanks.
                simondid
                any updates on this with the blank screen?
                • AlexMurphyA
                  AlexMurphy Banned @simondid
                  @simondid I just tried this and it works fine. After launching emulationstation from SSH. It displays the tty on my TV, then loads. I can launch ROMs no problem. It just shows the terminal on my TV for a few seconds then launches into the emulator. However, when I try to launch something from the RetroPie configuration menu, the Set-Up Script for eg, it does not show on the TV but on the device I am using to SSH with. I can then use my controller to navigate out of it.
                  DarkWolfD 1 Reply Last reply Reply Quote 0
                  • DarkWolfD
                    DarkWolf @AlexMurphy
                    As Emulationstation is rendered with OpenGL and "forced" to output through HDMI (or whatever output you use) and the retropie scripts are "rendered" on the command line, ES shows up on screen and retropie scripts/raspi-config on the console you launched ES with
                    System: Raspberry 3 Model B, RetroPie 4.2.1
                    Storage: 16gb Micro SD, 64gb USB Drive
                    Theme: Updated NBBA
                    Documentation solves many problems: https://retropie.org.uk/docs/
                      simondid
                      i just made a post describing my problem a bit more in detail
                      link text
                      @DarkWolf
                      is there any way to force the system emulator to be launch in a specific x session?
                      • AlexMurphyA
                        @simondid Pardon my lack of technical knowledge but ES will not run on X or when the X server is running, not on the Pi anyway. I'm just not familiar with RetroPie on other platforms but does it not use SDL?
                          simondid
                          hmm wired that is not a problem i'm having atm it dos require a kinda special command to launch es from my java program which is launch as part of an x session but i'm no linux expert
                          • AlexMurphyA
                            @simondid Me neither. I think we might both just be groping in the dark. Hopefully someone more linux-savvy will assist. I only chimed in to say it runs for me using a Pi3.
                            • DarkWolfD
                              @AlexMurphy Apologies... Yes it does, I mean it uses SDL, I guess I was irretated by the OpenGL parts in the source code I saw this day
                              @simondid So your problem is that the retropie script windows, or whatever, are "displayed on the wrong screen" leading to a black screen?
                              Theme: Updated NBBA
                                simondid
                                i'm not a 100% on what the problem is but what i think is happning is that the runcommand script which is run when you select a game is missing some kind of launch option just like when i'm launch es with this command
                                sudo -u pi env DISPLAY=:0 XAUTHORITY=/home/whoever/.Xauthority emulationstation
                                do you know if there is any way i can get some kinda logfile from the runcommand script ?
                                DarkWolfD Howitzer99H 2 Replies Last reply Reply Quote 0
                                • DarkWolfD
                                  DarkWolf @simondid
                                  @simondid Uhm, no, I'm not 100% sure but I think there is no logging going on
                                  Theme: Updated NBBA
                                  • Howitzer99H
                                    Howitzer99 @simondid
                                    @simondid All the error messages from these scripts will be logged in runcommand.log, which resides in the same directory that runcommand.sh is in.
                                    More info here: https://github.com/RetroPie/RetroPie-Setup/wiki/Runcommand
                                      jdewit
                                      I got it to work using 'screen'
                                      sudo apt-get install screen
                                      $ screen -d -m emulationstation
