    Hotkeys not working with SNES usb controller. works with Xbox.
    controller
    3 Posts 2 Posters 882 Views
    • a00682005A
      a00682005
      Hi everyone. First time poster here.
      Recently got a retropie setup. using retropie version 4.1 and an iBuffalo classic USB gamepad (USB snes controller)
      Started with an Xbox usb controller and everything worked fine. hotkeys and all. Moved over to the SNES controller, and while regular functions are good - hotkeys are not. I can configure hotkeys no problem in Retroarch, but when I load a game up, none of the hotkeys work. Hotkeys still work with the Xbox controller.
      Anyone able to share some insight?
      thanks,
      -Anumbers
        BuZz administrators @a00682005
        @a00682005 Hotkeys only work on player1 - do you still have the Xbox controller connected ?
        It should be enough to configure the controller in Emulationstation and then it should work in libretro emulators so long as it's player 1 - you can change USB order or use configuration editor to change input order.
        • a00682005A
          a00682005
          Hi Buzz.
          I have tried using the hotkeys on SNES controller with and without the Xbox controller connected. Both times it didn't work.
