Problems running my custom cfg's.
Hey guys. I run Retropie 4.1 w ES on a rasp 3b & had a bunch of tweaked configurations set up, with aspect ratios, shaders, @Floob s Rp video manager settings etc. But when i updated to 4.1.5 they stopped being my "default" config. I still have them, and i can load them up in the gui, but i cant for my life remember how to make them be my first choice so to speak.. Even if i save, tries different on/off save settings etc theyre gone when i quit the core. Do i have to rename the config to a stock name or something for it to be picked up..? Iv done this before but can't remember the solution. Any help is appreciated!
Nobody? :(
Ok, I guess the folder structure must have been altered or something.
I cant even get the right settings when i start from scratch, and saves the configuration. As soon as i start a new game, its back to what I think is retroarch.cfg.
Dosent matter how many override/core specific options I tinker with.f*ck it, I´m gonna go back to my old 4.1 backup image.
