    8bitdo SNES30 Controller doesn't work in RetroPie Setup
    8bitdo8bitdo snesretropiesetupcontrollers
    6 Posts 3 Posters 3.3k Views
    • E
      ebtalk
      I have two wired controllers that work when i'm in my RetroPie setup screen or when i'm selecting any button to configure a game emulator.
      I also have an SNES30 wireless controller. It works in the games but when i'm in my RetroPie setup screen, I can't even use it to scroll through my options. Any reasons why?
      Pi Model: (B, B+, 2 B etc..): B
      RetroPie Version Used: 4.01
      Built From: Premade SD image from RetroPie
      USB Devices connected: Two wired controllers, 1 keyboard
      Controller used: 8bitdo SNES30, two buffalo SNES controllers
      Error messages received: no working feature on wireless controller
      Emulator: (Name of emulator - if applicable): any emulator
      How to replicate the problem:
      meleuM 2 Replies Last reply Reply Quote 0
        meleu @ebtalk
        @ebtalk RetroPie-Setup (and other dialog based scripts) can only be controlled by the first joystick detected by the system. And it's usually /dev/input/js0.
        If there are USB controllers connected, they are surely detected before the bluetooth ones.
        Actually you can change the joystick that controls the dialogs, but it's a little tricky...
          meleu @ebtalk
          @ebtalk recently the retropie-setup scripts got an improvement on this subject. Now every connected joystick can control the dialog menus. Update your retropie-setup script and you'll see it. ;-)
          E 1 Reply Last reply Reply Quote 1
          • E
            ebtalk @meleu
            @meleu thank you. Huge fan of everybody's work here
              I think @hansolo77 will like to know it too.
              • hansolo77H
                hansolo77
                Heh that's great news! Will it work with the runcommand menus as well, or just the retropie-setup menus? In either case, that's a superb improvement! :)
                Who's Scruffy Looking?
