    OpenPHT (Optional x86/x64) Package Issues (and possible fix)
    pulseaudioopenpht plexportsoundaudio
    3 Posts 2 Posters 1.7k Views
    • johnodonJ
      johnodon
      Pi Model: N/A...Lenovo Thinkpad T420
      RetroPie Version Used: 4.1
      Built From: Source
      USB Devices connected: None ATM
      Controller used: Keyboard
      Error messages received: None (see below)
      Guide used: https://github.com/RetroPie/RetroPie-Setup/wiki/RetroPie-Ubuntu-16.04-LTS-x86-Flavor
      File:
      Emulator: OpenPHT
      Attachment of config files:
      How to replicate the problem: Perform basic install of Ubuntu 16.04.1 x64. apt-get upgrade. git clone retropie_setup script. Perform basic Retropie install via retopie_setup script. Install optional OpenPHT package via setup script. Launch OpenPHT from Ports menu in RP.
      Preface...
      I LOVE OpenPHT and am very glad to see a package available in RP! Even though it is only available for x86/x64, this suits my needs as I run my HTPC in an unRAID VM with GPU passthrough.
      Issues...
      1. OpenPHT hangs when trying to exit back to RP. I have added my user to the suoers list but that has not helped. If I launch OPHT manually (not via RP), I am able to quit back to desktop without issue.
      2. No audio when trying to play a movie in OpenPHT. I am able to get navigation sounds but nothing during playback. If I launch OPHT manually (not via RP), sound works fine.
      Troubleshooting...
      I decided to install the Kodi port to see if that behaved as expected and it did. I then noticed that OPHT has several audio devices listed when launched via RP whereas it has only 2 when launched directly. After a bit of digging, I found that OPHT is being called differently from RP than Kodi is (emulators.cfg).
      Contents of /opt/retropie/configs/ports/kodi/emulators.cfg
      kodi = "kodi"
      default = "kodi"
      Contents of /opt/retropie/configs/ports/openpht/emulators.cfg
      openpht = "pasuspender -- env AE_SINK=ALSA openpht"
      default = "openpht"
      I suspect that this entry is made by design due to some issues with PulseAudio. However, I made a backup of the existing file and created a new one that looked more like the Kodi one...
      openpht = "openpht"
      default = "openpht"
      Using this cfg file, I am able to exit OPHT withhout issue and also have audio during playback when launched via RP. So, where do we go from here?
      I have yet to test connecting to my TV via HDMI. I plan on doing this later and report back.
      John
      • johnodonJ
        johnodon
        UPDATE...
        I connected my laptop via HDMI to my TV. All I had to do was change the default audio device in Ubuntu sound settings (from builtin speaker to HDMI/Displayport) and I have perfect sound output in OPHT when launched from RP.
        AWESOMENESS!!! :)
        John
          gmoney2123
          Has this still worked overtime? Or have you run into issues with updating?
