    Help hopefully can be saved
    helpsavedwrong commandrestart
    4 Posts 3 Posters 1.3k Views
      maddyfresh1
      I was trying to set up my USB so I could run psx off of it. I typed the command cp -Rav /home/pi/RetroPie/roms and hit enter before I end the last code part which was usb0. I freaked out and pulled the plug (yea I know dont judge). Now it doesn't boot to the emulation station just to the command screen. Anything I can do to fix it so I dont have to start all over? O I have a rasp pie 3 with the latest raspberry
      • space cadetS
        space cadet
        You probably corrupted your sd card by not doing a proper shutdown. Try a new sd card
        • rbakerR
          rbaker @maddyfresh1
          @maddyfresh1 said in Help hopefully can be saved:
          You probably corrupted it if it was writing when you pulled the plug. Best to start again as advised by @space-cadet
            maddyfresh1 @rbaker
            @rbaker yea I sucked it up and started over.
