    Consoles missing - Running ROMs from a USB drive
    retropiesetupusb romsusb rom servicemissing systems
    13 Posts 5 Posters 5.3k Views
      rietzelucas
      Hey all,
      I am trying to run roms from a USB using the automatic method, as as laid out in the wiki, and am running into two issues:
      1. I am running a tripleboot pi - with Kodi and Raspbian - and found that once I plug my usb in, I lose my custom links to the other operating systems, and the Retropie settings menu (as seen below)
        0_1483660094917_upload-899fc0d1-50ae-4102-b57c-588a9085b7b5
        However, once I unplug the usb and reboot, those links return. Is there a way to keep these with the usb rom option?
      2. My USB drive currently has the Retropie folders (roms, bios, configs) with unzipped roms for the following consoles:
      • 3do (added folder myself)
      • amiga (added folder myself)
      • atari jaguar (added folder myself)
      • gameboy
      • gameboy advance
      • gamecube
      • n64
      • snes
      • psx
      • ps2
      • saturn
      • segacd
      • virtual boy
      However the only consoles that show up are:
      • gameboy
      • gameboy advance
      • n64
      • snes
      • psx
      • segacd
      Any suggestions on how to get these to show up?
      Thanks in advance!
      • rbakerR
        rbaker @rietzelucas
        @rietzelucas You need to install the emulators as explained here:
        https://github.com/retropie/retropie-setup/wiki/First-Installation#installing-additional-emulators--ports
          rietzelucas @rbaker
          @rbaker Thanks rbaker. Just after posting this I saw the forum post related to that. Just checking it out atm. Thanks for the quick reply!
          Any suggestions on how to resolve my first issue?
          columboscoatC 1 Reply Last reply Reply Quote 0
          • columboscoatC
            columboscoat Banned @rietzelucas
            @rietzelucas try adding an empty "ROM" folder for Kodi and Desktop / Raspbian on the USB. That might fix it. If empty folders don't work copy the folders over from the Pi to the USB. And RetroPie too, of course.
            • Darth_Farter87D
              Darth_Farter87
              I just made all operations, i copied a couple of neogeo rom in their folder, that's all' ok, but i didn't saw retropie game page (wifi, raspi option, retropie option, filemanager) and Dreamcast page with two rom (this Rom are in SD card Dreamcast folder)?
                rietzelucas @columboscoat
                @columboscoat I tried both creating a folder, and copying the existing folders from the RetroPie folder over and they still don't show :S
                • rbakerR
                  rbaker @rietzelucas
                  @rietzelucas Not really as I don't know what customisations you have in place.
                  • rbakerR
                    rbaker @Darth_Farter87
                    @Darth_Farter87 said in Consoles missing - Running ROMs from a USB drive:
                    If this is a question, I have no idea what you are talking about. Please open your own support request and read:
                      rietzelucas @rbaker
                      @rbaker I am using this triple boot build with OSMC. Outside of that all I've done is update raspbian and retropie to the latest builds.
                      rbakerR herb_fargusH 2 Replies Last reply Reply Quote 0
                      • rbakerR
                        rbaker @rietzelucas
                        @rietzelucas So it's now time to post some details on these custom links, config files, what you have done etc?
                        • herb_fargusH
                          herb_fargus administrators @rietzelucas
                          @rietzelucas we don't provide support for 3rd party images.
                            rietzelucas @rbaker
                            @rbaker To my knowledge the only modifications are in the es_systems.cfg file. It has been altered to include a call to a script to boot the pi into a different partition / os. The boot scripts are stored in the roms folder (/home/pi/RetroPie/roms/kodi/Kodi.sh).
                            Outside of this I don't believe there are any other modifications.
                            At the moment I have three games on my sd card, and found that when I mount the USB, I lose those games. So my thought is that perhaps the es_systems.cfg file is being overwritten to whatever is on USB, and therefore won't see anything on the SD card?
                              rietzelucas @herb_fargus
                              @herb_fargus It's not a 3rd party image, it's someone's preconfigured noobs setup with 3 partitions: one with Retropie, one with Kodi, and one with Raspbian. It's still the default Retropie image on top of a headless raspbian os. It was done this way so you would have less overhead when running Retropie (rather than having Raspbian with the GUI with both Kodi and Retropie installed and running on it).
