    Top requested arcade games for overlays
    overlayarcadepoll
    594 Posts 34 Posters 731.3k Views
      simbz23
      @UDb23 Edited the Moonwalker overlay with your suggestion, hope it came out alright!
      Overlay and launching image repo
      https://github.com/simbz33/retropie-overlay
        simbz23
        Spider-Man overlay complete
        meleuM 1 Reply Last reply Reply Quote 3
          meleu @simbz23
          @simbz23 There's an issue with the Spider Man overlay files on your repository. ;-)
            simbz23 @meleu
            @meleu said in Top requested arcade games for overlays:
            So weird, I thought I uploaded and saved the changes. Files should be there now!
              UDb23 @simbz23
              @simbz23 overlay image filenames should include artist name: gamename_simbz-ovl.png
              Script works fine even without it ... but people should know you made that overlay ;-)
                meleu @UDb23
                @UDb23 I was thinking about it. We can create an optional field in the info.txt. I'm not sure about the best name: artist or maintainer? Maybe both :).
                They will be completely optional. My intention is to give some credits in the dialogs while installing the files...
                Suggestions?
                  UDb23 @meleu
                  @meleu What about creator, author(more for books...), producer.
                  Or even simpler: Made_by
                    meleu @UDb23
                    @UDb23 let's stick with creator. You can use it in your files if you want from now on. I'll make the new script show this info in the dialogs.
                    It's completely optional, so you don't need to update all the info.txt files in your repo.
                      UDb23 @backstander
                      @backstander said in Top requested arcade games for overlays:
                      do you think you could make an overlay for River City Ransom
                      Available now here: 2 versions and launching image.
                      B 1 Reply Last reply Reply Quote 3
                        backstander @UDb23
                        Thank you @UDb23!
                          meleu @UDb23
                          @UDb23 said in Top requested arcade games for overlays:
                          I think it might be best if @simbz23 makes his own repo
                          Right. Makes sense.
                          I changed my mind about it. If the overlay creator is just a casual creator, maybe it's better to contribute to @UDb23 's repo.
                          The @UDb23 's repo is more active, and we can fix eventual problems in the info.txt and/or config files more quickly.
                          @UDb23 maybe you should create a contrib folder on the repo to put files sent by others.
                            UDb23 @meleu
                            @meleu OK.
                            Only good quality overlays (talking about image quality, not personal taste) and supplied with cfgs and info.txt can be accepted for inclusion in the "official" Repo.
                              simbz23
                              @meleu @UDb23 this sounds like a good idea. How should I transfer over my existing and new stuff down the road to you @UDb23 ?
                                meleu @simbz23
                                @simbz23 I'm gonna submit some files to his repo tonight, and I can send yours too. ;-)
                                Cheers!
                                  meleu @UDb23
                                  @UDb23 could you check the PR 32?
                                  Wow! Your repo is becoming very rich! :)
                                  UDb23U 1 Reply Last reply Reply Quote 2
                                    UDb23 @meleu
                                    Merged.
                                    It's a joint project so not really mine... our :-))
                                      UDb23
                                      @meleu:
                                      edited info.txt file specification to include creator item.
                                      btw when specifying clones (or in general when having multiple values of an item) should there be a space after the semicolon or just the semicolon as separator?
                                        meleu @UDb23
                                        Do as you wish. The script is smart enough to deal with it. :-)
                                        Every space between the semicolon and the next non-space character is ignored. Same thing in the end, every space between the last non-space char and the closing quote is ignored.
                                        [edit]
                                        Example of valid entry:
                                        rom_clones = "     clone1      ;    clone2;clone3; clone4          "
                                          UDb23 @meleu
                                          Really professional approach !! Well planned and done.
                                            UDb23
                                            Bombjack overlay created.
                                            This was quite tough to make. Again almost no decent quality bezel image so artwork was created in vectors from scratch.
                                            The overlay is an own composition based on actual arcade bezel, cabinet side art and cpo.
                                            EDIT: updated ovl image
                                            You can find this and other overlays in the rpie-ovl repository.
                                            And if you want an easy way to install them, @meleu created a great dedicated script.
                                            Perform these commands on your RetroPie:
                                            git clone --depth 1 https://github.com/meleu/rpie-art
                                            cd rpie-art
                                            bash rpie-art.sh
                                            After launching rpie-art.sh script you just have to follow the instructions in the dialog boxes. Once you have the rpi-art.shscript, choose the Update option to get all the latest art in the repository.
