    Top requested arcade games for overlays
    overlayarcadepoll
    594 Posts 34 Posters 724.4k Views
      simbz23
      Popeye overlay in the repo!
      Overlay and launching image repo
      https://github.com/simbz33/retropie-overlay
        simbz23
        Launch image to go along with the overlay. Will be posting my collection of homemade and found launch images shortly...@meleu is this topic an OK place to show game specific launch images?
          simbz23
          @meleu also If I included a launch image in each game specific overlay folder in my repo, would that screw up your script?
            backstander @simbz23
            @simbz23
            Here is an example of what @UDb23 did for a launch image:
            https://github.com/UDb23/rpie-ovl/tree/master/arcade/Burning Force
              meleu @simbz23
              @simbz23 said in Top requested arcade games for overlays:
              Not a problem for me. But maybe you can make your art more visible for other users if you create a new topic.
              Nop. But if you want to make "installable" through the script, you need to fill the info.txt accordingly.
                simbz23
                @backstander thanks brother!
                @meleu got it, sounds good. Tell me, can I just put a launch image in a game folder and the script will still find and install it, as long as the info files is correct? I have launch images that don't have overlays for them yet, and I may or may not make one for them...
                  meleu @simbz23
                  Yes. And you can fill the info.txt for launching images only. Like this: https://github.com/UDb23/rpie-ovl/blob/master/contrib/meleu/Contra/info.txt
                  But please, take a look at the info.txt rules here: https://github.com/meleu/rpie-art/blob/master/INFO.md
                  The info.txt files in your repo don't have the system entry, and the new script is ignoring them. I've made a Pull Request to your repo adding the system to the files but you didn't merge it.
                  Also, as I said above (and @UDb23 agreed), casual creators can submit their files to @UDb23 's repository putting the files under contrib/CONTRIBUTOR_NAME folder. It's a good solution cause his repo has more eyes to detect problems in info.txt files. I sent your files to his repository, but I see that you're enjoying creating art and maybe you are more than a "casual creator". :-)
                  If you want to make your repo a client for my script, you need to:
                  1. Fill your info.txt files correctly (follow the rules here).
                  2. Pay attention at github notifications, it's important when someone report a new Issue or submit a Pull Request fixing some problem.
                  If you don't want/don't have time to do these things, maybe it's better to simply know how to put your files in contrib/simbz33 in the @UDb23 's repo (know how to make a Pull Request).
                  It's up to you.
                  By the way, your art is really cool. Good quality, talking about image quality and personal taste! :-)
                    simbz23
                    @meleu Got it, thanks again for all the help. Corrected my existing info files and will make sure future ones are good to go as well!
                    And you are right, I will pay more attention to the github notifications, so we can keep everything running smooth!
                    Lastly, thank you so much for the compliment, means a ton coming from you and this community. You all have given me a lot joy and help with Retropie so giving back is the least I could do!
                      simbz23
                      Punch out, done...
                      B 1 Reply Last reply Reply Quote 2
                        Nice overlay @simbz23 !
                        I made a new Pull Request to @UDb23 's repo adding this overlay and Popeye!
                          UDb23 @backstander
                          @backstander As far as I understand @simbz23 would like to keep his overlays in his own Repo on github and @meleu 's script will include them.
                            UDb23
                            Another unforgettable arcade game I played a lot (on the real cab!)
                            Silkworm has interesting graphics and relatively fast-paced gameplay. The player can take control of a Jeep mounted with a machine gun or a Helicopter mounted with forward and downward firing guns. Two players can work simultaneously and cooperatively against enemies, with one playing as the Jeep and one as the Helicopter. (ref. Wikipedia)
                            UDb23U 1 Reply Last reply Reply Quote 4
                              UDb23 @UDb23
                              @UDb23 Will also create "scrape" and launching image soon.
                                simbz23
                                @meleu @UDb23 So I have an issue with NBA JAM - Tournament edition.
                                There is the original parent rom that is "nbajamte" but I also have Revision 2 which depends on the parent rom, called "nbajamt2".
                                This revision has secret mortal kombat characters as some of you may or may not know. Do I use the "clone" value in the info file, or is there more I have to do then that, to get the script to pick them up? Wasn't sure if a revision of a parent rom is considered a clone or not
                                UDb23U meleuM 2 Replies Last reply Reply Quote 0
                                  UDb23 @simbz23
                                  @simbz23 As far as I understood what the script does when you specify a clone within info.txt is that it will generate the same config files for the clone as for the original game (naming the ... zip.cfg filename with the name of the clone of course). In other words if the clones use the same game area as the original, adding the "clones" line into info.txt of the original is enough.
                                    meleu @UDb23
                                    @UDb23 you are right, buuuut, I didn't implement the "clone config management" yet. Will do soon.
                                      meleu @simbz23
                                      If you made an image specific for this clone, just do as if it is the parent. Actually the script don't care about this parent/clone stuff.
                                        simbz23
                                        @UDb23 @meleu Thanks fellas!
                                          simbz23
                                          NBA Jam and Batman, done...
                                            simbz23
                                            All credit goes to @UDb23 for this Donkey Kong overlay, amazing work! All I did was add the instructions card to it, for my own personal taste, but may or may not appeal to some people here....
