    Top requested arcade games for overlays
    overlayarcadepoll
    594 Posts 34 Posters 848.6k Views
      UDb23 @GreenHawk84
      @greenhawk84 Heres' the overlay you asked for ;-)
      More info here.
      Enjoy!
      • GreenHawk84G
        GreenHawk84
        @UDb23 can you access my bezels? Is it working for the script?
          UDb23 @GreenHawk84
          @greenhawk84 I noticed there is no info.txt and files are not in a folder. Info.txt is mandatory, one per game as described by @meleu.
            meleu @UDb23
            @udb23 in this doc: https://github.com/meleu/rpie-art/blob/master/INFO.md
              UDb23 @meleu
              @meleu You already posted it in this thread (here); probably @GreenHawk84 missed it.
              "repetita iuvant" ancient Romans used to say. ;-)
                meleu @UDb23
                @udb23 said in Top requested arcade games for overlays:
                Looks more like a Harry Potter thing. Wingardium Leviosa! :-)
                  UDb23 @meleu
                  @meleu said in Top requested arcade games for overlays:
                  Wingardium Leviosa!
                  Not that much magic !
                  It's just latin, basically meaning: "Repeating helps"
                  • GreenHawk84G
                    GreenHawk84
                    @UDb23 @meleu Yes yes, I saw those tips. There is a learning curve for me at Github, but I'll see what I can do to get it looking more like UDb23's structure.
                      UDb23 @GreenHawk84
                      @greenhawk84 said in Top requested arcade games for overlays:
                      make an overlay for Turtles in Time arcade?
                      "Turtles in Time" overlay just made, right now, and available in the Repo:
                      No time for checking image/installing it, so let me know if everything is ok (and if you like it of course).
                      Tried to recreate the feel of the original Arcade sideart / Flyer:
                      As said the image you posted is custom artwork and it's based on this SNES Boxart:
                      It's a great boxart but to use the characters from that image for an overlay would mean a huge amount of time just cutting 'em out in a clean way !! Time that to me is not worth the effort.
                      If someone has the characters already I would be more than happy to use them.
                      TMNTturtlguyT GreenHawk84G 2 Replies Last reply Reply Quote 2
                      • TMNTturtlguyT
                        TMNTturtlguy @UDb23
                        @udb23 What you have looks good, but the new nickelodean turtles just aren't the same! Here are a few that might be easier to clean up. If you want i can try to help when i have some free time.
                        UDb23U 2 Replies Last reply Reply Quote 0
                          UDb23 @TMNTturtlguy
                          @tmntturtlguy said in Top requested arcade games for overlays:
                          I see. Yes, these are quite easy to cut out and first image has enough resolution. Will create a new version of the overlay using them.
                          MrJordaaanyM 1 Reply Last reply Reply Quote 1
                          • GreenHawk84G
                            GreenHawk84 @UDb23
                            @udb23 I like it but as @TMNTturtlguy said, the new age turtles don't feel right. Did you recreate the portal? If so, that's pretty close! I may still try this one out myself but this is definitely a tougher one.
                            • GreenHawk84G
                              GreenHawk84
                              Found this online. Not bad, but I don't like how they covered the bottom corner with that huge instruction.
                                UDb23 @GreenHawk84
                                @greenhawk84 I have seen that one before making my own; as you said the instruction sheet does not fit. Also the boxes around the turtles, not in line with original art.
                                Yes. I recreated the "portal" fully (inkscape: spiral tool + blurring and gradient in the background).
                                • GreenHawk84G
                                  GreenHawk84
                                  @UDb23 for the vertical bezels that are being made here, they cannot be used with a shader correct? At least with a shader that works properly? I ask because when I enabled the crt.pi shader I got the rainbow colors that @dankcushions has worked to get rid of by changing/adjustments.
                                  Also, will crt.pi work with integer scale enabled as some of the bezels require?
                                    UDb23 @GreenHawk84
                                    I'm not using shaders (personal taste) but months ago I tested it and I can't remember specific issues. There is a specific crt-pi-vertical shader; scale integer should be ON.
                                    Details in this post.
                                    GreenHawk84G 1 Reply Last reply Reply Quote 0
                                    • GreenHawk84G
                                      GreenHawk84 @UDb23
                                      @udb23 thanks yes I have followed that thread for a long time, I was just curious because I think in order to use that shader properly you could not use these vertical bezels at the same time. The game image stretches horizontally beyond borders.
                                        UDb23 @TMNTturtlguy
                                        @tmntturtlguy New overlay ready!
                                        Thanks for pointing it out.
                                        • GreenHawk84G
                                          GreenHawk84
                                          I went ahead and took a stab at TMNT2.
                                          UDb23U 1 Reply Last reply Reply Quote 2
                                            UDb23 @GreenHawk84
                                            @greenhawk84 Nice. Turtles fans now have quite of a choice.
