    Tried Reimage, now won't turn on - Please Help
    blank screenno loadwont startreimageblank
    1 Posts 1 Posters 825 Views
    • Z
      zero_cool
      I had an issue (now kinda not relevant). I found a few help topics that suggested I reimage and just start over again. I reformatted the Micro SD. Ran Win32 disk imager to put the image back on. now it won't load. As in my 360 controller lights up for a second and nothing comes up on the screen. I have no idea what to do now. It did work before it had the other problems.
      Pi Model or other hardware: Pi Zero
      Power Supply used: the one from the kit ~1A I believe
      RetroPie Version Used 4.1
      Built From: file for Pi zero from retropie website
      USB Devices connected: otg cable to amazon mini hub to xbox 360 controler
      Controller used: xbox 360
      Error messages received: N/A
      Guide used: for setup DIY NES mini killer by Snazzy labs on youtube
      File:
      Emulator: N/A
      How to replicate the problem: unknown
