    Wiimote Still Not Connecting after Following Steps
    wiimotenot workingwminput
    7 Posts 2 Posters 2.8k Views
    • trigger_deathT
      trigger_death
      Pi Model: Raspberry Pi 3 - Model B
      Power Supply: CanaKit 5V 2.5A Raspberry Pi 3 Power Supply / Adapter / Charger
      RetroPie Version: 4.1
      Built From: Pre made SD image. (Boots on Micro SD, filesystem is on Flash Drive)
      USB Devices: Keyboard, Flash Drive with filesystem on it
      After following the steps on this guide here I still can't seem to get single Wiimote I configured to connect. Bluetooth sees it but it won't connect after setting up all the scripts and rules.
      Steps and information about the steps I took.
      • The RetroPie image is fresh from today. I did sudo ./retropie_setup.sh but for some reason it didn't ask me anything related to choose Binary-based installation.
      • wminput has been installed
      • nano /etc/udev/rules.d/wiimote.rules
        KERNEL=="uinput", MODE="0666"
      • nano /home/pi/mywminput
        Classic-Controller
        Classic.Dpad.X = ABS_X
        Classic.Dpad.Y = ABS_Y
        Classic.LStick.X = ABS_HAT0X
        Classic.LStick.Y = ABS_HAT0Y
        Classic.RStick.X = ABS_HAT1X
        Classic.RStick.Y = ABS_HAT1Y
        Classic.A = BTN_A
        Classic.B = BTN_B
        Classic.X = BTN_X
        Classic.Y = BTN_Y
        Classic.Minus = BTN_SELECT
        Classic.Plus = BTN_START
        Classic.Home = BTN_MODE
        Classic.L = BTN_TL
        Classic.R = BTN_TR
        Classic.ZL = BTN_TL2
        Classic.ZR = BTN_TR2
        WiiMote
        Wiimote.A = BTN_A
        Wiimote.B = BTN_B
        Wiimote.Dpad.X = ABS_Y
        Wiimote.Dpad.Y = -ABS_X
        Wiimote.Minus = BTN_SELECT
        Wiimote.Plus = BTN_START
        Wiimote.Home = BTN_MODE
        Wiimote.1 = BTN_X
        Wiimote.2 = BTN_Y
        Nunchuk
        Nunchuk.C = BTN_C
        Nunchuk.Z = BTN_Z
        Plugin.led.Led1 = 1
      • hcitool scan resulted in "00:1C:BE:F2:D8:64 Nintendo RVL-CNT-01"
      • nano /home/pi/bin/attachwii.sh
        #!/bin/bash
        sleep 1 # Wait until Bluetooth services are fully initialized
        hcitool dev | grep hci >/dev/null
        if test $? -eq 0 ; then
        wminput -d -c /home/pi/mywminput 00:1C:BE:F2:D8:64 &
        else
        echo "Blue-tooth adapter not present!"
        exit 1
        fi
      • I've executed chmod 775 /home/pi/bin/attachwii.sh and even added a sudo in front to see if that helps.
      I've rebooted multiple times after all this and the wiimote still refuses to connect when ES is running after holding down 1+2 or the red sync button.
      • trigger_deathT
        trigger_death
        So I've figured out something.
        if you run /home/pi/bin/attachwii.sh from the terminal the Wiimote can connect. So for some reason the executable isn't starting up like it should.
        Does anyone have any insight onto why /home/pi/bin/attachwii.sh isn't running on startup?
        • trigger_deathT
          trigger_death
          I think I've finally solved this. I have no issues currently but I'm worried some might pop up. Anyways, here's what I did.
          The RetroPie 3.x section in Register Wiimotes Before Emulationstation Starts actually has an unwritten counterpart for what to do in RetroPie 4.1 (4.x maybe?).
          • Edit /etc/profile.d/10-retropie.sh.
          • Follow the instructions for 3.x except put the line before if [ "tty" = "/dev/tty1" ]; then
          The result should be this:
          rebootWithoutWiimotes=0 /home/pi/bin/attachwii.sh
          if [ "`tty`" = "/dev/tty1" ]; then
              bash "/opt/retropie/configs/all/autostart.sh"
          fi
          • Follow the instructions for My SSH terminal is unusable and giving me socket control errors! in the Known Issues section.
          • This will make sure the terminal isn't flooded and fixes a problem where at least I couldn't access the RetroPie through SSH or SFTP.
          The wminput lines in /home/pi/bin/attachwii.sh should now look like this:
              wminput -d -q -c  /home/pi/mywminput XX:XX:XX:XX:XX:XX > /dev/null 2>&1 &
          After doing all that, order has been restored and the Wiimote pairs perfectly! I hope this helps anyone whose come across this. I'm not the best at writing wordy guide instructions so I'd recommend someone update the wiimote guide to have information for 4.1 (4.x maybe?).
          herb_fargusH 1 Reply Last reply Reply Quote 1
          • herb_fargusH
            herb_fargus administrators @trigger_death
            @trigger_death it's a wiki. Anyone can add to it. Feel free.
            • trigger_deathT
              trigger_death
              Alright it's updated now. I'm going to assume the file has been changed from 10-emulationstation.sh to 10-retropie.sh starting in 4.0. I'm not entirely sure how to go about confirming that though.
              • herb_fargusH
                @trigger_death looks like it's there in the code:
                https://github.com/RetroPie/RetroPie-Setup/blob/5cbf1c97e50bd67d67c19db1dbfc298d5d2e8afc/scriptmodules/supplementary/autostart.sh#L29
                I'm not super familiar with the auto start scripts and I don't have a Wii mote to test but if you have it running then great!
                Thanks for updating the docs so that others can benefit from it
                • trigger_deathT
                  trigger_death
                  Yup no problem. I also feel like the guide should be more specific in stating the SSH and terminal spam problem, other than in the issues section that may not be noticed. I'm just not sure what section to state it in.
