    No Wifi Results after using Disconnect/Remove Wifi Config
    wifinot workingnetwork
    33 Posts 2 Posters 9.2k Views
    • trigger_deathT
      trigger_death
      Pi Model: Raspberry Pi 3 - Model B
      Power Supply: CanaKit 5V 2.5A Raspberry Pi 3 Power Supply / Adapter / Charger
      RetroPie Version: 4.1
      Built From: Pre made SD image. (Boots on Micro SD, filesystem is on Flash Drive)
      USB Devices: Keyboard, Flash Drive with filesystem on it
      So when I got my Pi 3 and setup RetroPie the Wifi worked perfectly. I decided to disconnect from the wifi for awhile using Disconnect/Remove Wifi Config. The next day I wanted to switch back to my main Wifi and now no results are showing up. This is strange because 1) My Wifi is working on my phone and 2) there are multiple other Wifis networks in the area that should show up.
      It should be obvious but I'm only speculating that the mentioned action caused the issue, although I can't find information leading me to think one way or the other. The only other possibly related thing I've done is configure wminput bluetooth for Wiimotes but I doubt that's related.
      columboscoatC 1 Reply Last reply Reply Quote 0
      • columboscoatC
        columboscoat Banned @trigger_death
        @trigger_death something in here might help. http://unix.stackexchange.com/questions/90778/how-to-bring-up-a-wi-fi-interface-from-a-command-line
        • trigger_deathT
          trigger_death
          So sudo iwlist wlan0 scan results in showing the Wifi I intend to use as well as a printer. I'm still not sure how to connect to it but I'm also worried why it's not showing up in the Wifi Menu, does the Disconnect/Remove Wifi Config actually break Wifi through RetroPie?
          • columboscoatC
            @trigger_death It can do. Go to terminal. Type these commands one after each other following the conclusion. sudo apt-get update then sudo apt-get dist-upgrade. Try that first. If you still have problems please come back to me. Reboot after everything has finished btw!
            • trigger_deathT
              trigger_death
              Welp that fixed it! Thank you so much! ^_^
              Now I'm wondering. What caused this to happen? If it was what I presumed then is there a proper way to disconnect from Wifi?
              columboscoatC 1 Reply Last reply Reply Quote 1
              • columboscoatC
                @trigger_death Stop asking questions and clock GoldenAxe! Some people...
                • trigger_deathT
                  trigger_death
                  Okay actually it's not fixed. I tried to connect to my Wifi network and it failed. When I went back to the Connect to Wifi network the list was empty again. -__-
                  • columboscoatC
                    @trigger_death So, you got connected? Briefly?
                    • trigger_deathT
                      trigger_death
                      Well connected in the sense that it saw all the available Wifis for a brief moment.
                      • columboscoatC
                        @trigger_death Power down the Pi in the proper manner. Restart your home router while the Pi is off. Keep the router off for at least a minute. Reboot the router.Wait until it sorts its'self out. Re-connect the Pi to the electricity. What happens?
                        • trigger_deathT
                          trigger_death
                          The list is still empty.
                          • columboscoatC
                            @trigger_death type iwconfig into the terninal. What is the output. And I mean the Pi terminal...
                            • trigger_deathT
                              trigger_death
                              wlan0     IEEE 802.11bgn  ESSID:off/any
                                        Mode:Managed  Access Point: Not-Associated       Tx-Power=31 dBm
                                        Retry short limit:7   RTS thr:off   Fragment thr:off
                                        Power Management:on
                              lo        no wireless extensions.
                              eth0      no wireless extensions.
                              • columboscoatC
                                @trigger_death your wifi is off. Do you have an ethernet cable and access to your router?
                                • trigger_deathT
                                  trigger_death
                                  Yes and yes.
                                  columboscoatC 2 Replies Last reply Reply Quote 0
                                  • columboscoatC
                                    @trigger_death plug it all in and reboot.
                                    • trigger_deathT
                                      trigger_death
                                      If you mean connect my Pi to ethernet, it's been on ethernet this entire time.
                                      • columboscoatC
                                        @trigger_death then post iwconfig output again.
                                        • columboscoatC
                                          @trigger_death Ha! Sorry!
                                          • trigger_deathT
                                            trigger_death
                                            I didn't notice any differences. Like I said I've been on ethernet since the start. :P
                                                      Power Management:on
