    No Wifi Results after using Disconnect/Remove Wifi Config
    wifinot workingnetwork
    33 Posts 2 Posters 9.1k Views
    • columboscoatC
      columboscoat Banned @trigger_death
      @trigger_death DO YOU HAVE A CUSTOM SETUP? IF NOT PLEASE REFLASH THE IMAGE. IT WILL BE QUICKER THAN MANUALLY CONFIGURING THE CONNNECTIVITY.
      • trigger_deathT
        trigger_death
        Nope, I don't have a custom setup but... wouldn't reflashing the image erase everything I've modified on my RetroPie since setting it up?
        columboscoatC 1 Reply Last reply Reply Quote 0
        • columboscoatC
          @trigger_death it would... but it means you have a fairly standard setup. Just as a by the way have you tried just reconnecting to wifi via the ES menu?
          • trigger_deathT
            trigger_death
            That's how I've been trying to connect to the Wifi the entire time. Through the RetroPie Wifi App.
            • columboscoatC
              @trigger_death Have you tried via the desktop or through the commmand line interface /terminal?
              • trigger_deathT
                trigger_death
                I haven't installed any desktop interface and I'm not familiar with how to do it through terminal.
                • trigger_deathT
                  trigger_death
                  Also I'm flashing a new image to a spare Micro SD I have.
                  • columboscoatC
                    @trigger_death go to the desktop. I assume it is PIXEL. Top right hand corner. Do you see a wifi logo or a broken connection?
                    • trigger_deathT
                      trigger_death
                      startx doesn't seem to be recognized.
                      If I recall, the desktop environment isn't installed with RetroPie by default.
                      columboscoatC 2 Replies Last reply Reply Quote 0
                      • columboscoatC
                        @trigger_death it's not.
                        • columboscoatC
                          @trigger_death Really, I would just boot a new image if I were you. Debugging this is not worth it and it's 03:30 am here so... I'm out. Good luck!
                          • trigger_deathT
                            trigger_death
                            Thank you for the help
                            • trigger_deathT
                              trigger_death
                              I have now narrowed the steps to reproducing this issue on a newly flashed USB and boot Micro SD.
                              • Use this guide to enable wiimote connections.
                              • Install the "old format hiscore.dat" in the mame2003 bios as explained in the high scores section here.
                              • Enable Root Login over SSH by doing the following:
                              • sudo nano /etc/ssh/sshd_config
                              • Change PermitRootLogin to "PermitRootLogin yes"
                              • Enter "sudo passwd root" then enter in the root password.
                              • Restart for changes to take effect
                              I'm still trying to narrow it down even farther.
                              So far, finishing with the Wiimote steps has triggered the issue and finishing with the hiscore.dat has triggered the issue (which is really strange).
                              Edit: Upon narrowing it even further. You don't need to be running off USB for this to occur. All you have to do is follow the wiimote connection guide to cause this issue.
                              Based on this info I can assume that it's also inconsistent when the issue will first occur after following these steps, as one reboot often wasn't enough to cause it.
                              I've now narrowed down the cause to the following line in "/home/pi/bin/attachwii.sh".
                              wminput -d -q -c  /home/pi/mywminput 00:1C:BE:F2:D8:64 > /dev/null 2>&1 &
                              The '&' at the very end of the line is the cause of this. Removing the '&' and then running it does not cause the same issue.
                              Now the problem seems to be that removing the '&' at the end will not allow your system to finish booting if you have "/home/pi/bin/attachwii.sh" run on startup. Now the question is getting a little more specific as what to fix so I'll create a new post and link it below:
                              https://retropie.org.uk/forum/topic/7296/wminput-command-with-on-the-end-breaks-wifi
