    issue with analog stick
    analog stickxbox 360 controler
    12 Posts 4 Posters 2.9k Views
      Coldpaw
      Pi Model or other hardware: (3)
      Power Supply used: (2,5 offical one)
      RetroPie Version Used (4.01):
      Built From: (Pre made SD Image from RetroPie website)
      USB Devices connected: xbox 360 controller reciver
      Controller used: xbox 360 controller
      Error messages received: none
      Emulator: (lr-pcsx-rearmed)
      How to replicate the problem: When i move my left analog stick to down right the character walks instead of running all the other ways works fine. Sorry if you dont understand can upload a video if needed
      • I
        ivvi @Coldpaw
        @Coldpaw you can use xbox controller in dreamcast and n64 emulators?
          Coldpaw
          I dont know i have not tryed these emulators:)
            edmaul69 @Coldpaw
            @Coldpaw if you do a search on here for raphnet northwest fix it might be the solution to your problem.
              Coldpaw
              Still having this problem:(
                edmaul69 @Coldpaw
                @Coldpaw did you try the raphnet northwest fix?
                C 2 Replies Last reply Reply Quote 0
                  Coldpaw @edmaul69
                  @edmaul69 No what is this?
                    Coldpaw @Coldpaw
                    @Coldpaw Alright i readed up on some of it i will try to install it:) thanks man hope it works
                      Coldpaw @edmaul69
                      @edmaul69 alright i installed it and it took a long timeXD but sadly it did not fix it:(
                        Coldpaw
                        just plugged in my brothers wired xbox 360 controller and it works all fine:/
                          BuZz administrators
                          You could try adjusting controller sensitivity in the core options for the emulator. (Start+x / quick menu / options or so)
                            Coldpaw
                            Thanks for the reply but i dont find any of these options
