    N64 USB and XBOX 1 wired controller setup
    controller
    1 Posts 1 Posters 861 Views
    • W
      WanderingBango
      I am trying to get my n64 usb controller and xbox 1 controllers to be recognized but no luck yet. Ive tried a few guides but no luck. Ive programmed the n64 controller using "configure input" but it doesnt work on any games; however it will work in the retropie menu screens (switching between systems, choosing a game). As soon as the game launches the controller stops working. Im happy to attach logs just unsure which would be most helpful.
      Ill try to follow the format requested.
      Pi Model or other hardware: Pi 2
      Power Supply used: canna kit 5v 2.5a
      RetroPie Version Used: 4.1 (i downloaded it from retropie website, but then ran update from the raspi-config and updated it, so may be a later version.)
      Built From: https://retropie.org.uk/download/ using applepi-baker
      USB Devices connected: rii keyboard
      Controller used: buffalo classic snes, xbox 1, n64
      Guide used: (Mention if you followed a guide): https://retropie.org.uk/forum/topic/376/n64-usb-controller-best-input-config and http://smartretro.co.uk/forums/viewtopic.php?f=3&t=22
      Emulator: (Name of emulator - if applicable): both gles2rice and gliden64
